Wear on rear cassette...
meaculpa
Bikes: 07 Bianchi Volpe
This past summer I had to replace the rear cassette & chain on my commuter. 500+ miles later, the teeth are worn & the chain is slipping...again. I wonder if its my constant shifting thats to blame. I have a habit doing this I think because of being protective of my knees. But my lack of skill makes frequent shifting harsher on the drivetrain.
The cog was Sram I think.
Bikes: Trek 1000, two mtbs and working on a fixie for commuting.
Depending on riding style (i.e. shifting), weather, level of components and a whole bunch of other things, around 500 miles is not too bad for the set.
I would add that you should make sure it shifts very well (read 'perfect') to prolong life. Having the whole set up a *little* off can shorten life due to premature wear.
Quoted: 303 Post(s)
Liked 136 Times
500mi is lousy mileage for either cassette or chain. My experience,
not commuting or off road and not being compulsive about clean
or lube, is that a chain will last 3000-6000mi, a cassette
will last two chains, and chainwheels (the most used ones anyway)
will last 3 chains. Others get better or worse, but 500 is way low.
Riding a very gritty chain in all weather conditions
will certainly accelerate wear and use up the cassette faster.
My longest lived setup was the 8spd front drive on my bent in
which the chain, cassette and
CW all lasted 16,000 mi. Chain elongation was about 3/32
at change out and it was a KMC chain.
Shifting has very little to do with cassette wear, and brifter users
in general shift 3-4x as much as downtube shifters do, with no
difference in wear rates in my experience.
Mr. Dopolina
Bikes: KUUPAS, Simpson VR
Quoted: 149 Post(s)
Liked 117 Times
Quoted: 2026 Post(s)
Liked 1,096 Times
My experience agrees with sch.
Liked 7 Times
I don't think you can wear a cassette enough in 500 miles to cause chain slip.
If your shift cable needs adjusting the chain can off and on a cog or autoshift to another cog causing apparent chain slip. Any decent cassette should last 10,000 miles or more if the chain is replaced before excessive elongation occurs.
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
In other words, it'd be almost impossible to wear out a chain and cassette in 500 miles. His drivetrain (i.e., rear der and perhaps front too) needs adjustment, cleaning and lubing.
