Titanium/light 10mm axles?
partly metal, partly real
Bikes: Hummer H2
Took a spill on nye (gf cut me off with a sharp left while i was in her blindspot which turned my front wheel hard) and fuxed my rear axle. Still works, but i was thinking about replacing it. It's a hollow steel axle, whatever comes on the mavic ellipse wheelset. I was thinking about replacing it with something lighter if avalable. i know bmx hubs are sometimes made with 14mm titanium axles; do you guys know if there are 10mm ones? If not, do you know of any especially light hollow axles? I figure if i'm replacing it, i may as well shed a few grams in the process.
Bikes: 2006 Lemond Etape 105/Tiagra
Bikes: Hummer H2
neither was i until what i now realize is a welded cap on the end tore off from the spill. pretty nutty.
the strap clip from my rx-1 is bent too. kinda sucks...
dan bones!
Bikes: iro mark v for street, sh itamori peloton for track
i've heard all sorts of claims about how much of a ***** it is to replace hub components with the ellipse wheelset. all sorts of proprietary and what have you.
i know it can probably be done, but i get the feeling it'll be waaaay more of anexpensive hassle than you want it to be. its also possible that the hub body will only work with another mavic axle.
Bikes: Hummer H2
i see.
maybe i'll just grab another mavic hollow axle. i'll email them and post a reply...
