Shimano 7801-sl hub race
R.E.Member
Bikes: Cannondale, Kirk
I just read a relatively new thread that seemed to address my issue here:
https://www.bikeforums.net/bicycle-mechanics/376469-races-ruined-what-s-best-course-action.html
but i wanted to make sure that the hub issues were the same.
I've got a 7800 rear hub that has scoring on both the outer cone and inner hub races. Is the inner hub race replaceable? Or do I need an entirely new hub? Just curious as the above thread adresses a mountain hub and mine is obviously for the road.
Thanks in advance!
Thanks in advance!
Quoted: 2026 Post(s)
Liked 1,096 Times
AFAIK, Shimani hubs do not have replacable inner races. The cone can be replaced but the inner race is fixed in place.
BTW. are you sure the races are really scored and you are not seeing just the ball track? There will be a brighter ring where the balls circulate on both the cone and the inner race and this is normal and perfectly fine. A damaged hub has pits or obvious scratches and damage to the cone and/or inner race.
R.E.Member
Liked 1,096 Times
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
Sounds like the cone was too tight. Unless there is deep pitting or a deep groove, I suggest installing new balls and putting the wheel back into service. When adjusting the cones you want them a little loose off the frame because the clearance will go away when the quick release is clamped down. The groove is not a good thing per say but the wheel will roll just fine anyway in my experience.
Good luck.
Good luck.
R.E.Member
Thanks all.
Yeah, by darker I was referring to it being a rough groove. You can clearly feel it when you run your finger nail across it. You can clearly feel the roughness in the frame when the wheel is rolling too. I suspect that the cones were too tight as well. Next time I'll check before riding new Shimano's.
Waterrockets actually warned me about that once, and I only checked the front. Of course, Murphys law dictated the rear to be screwed up.
Liked 1,096 Times
