Spoke Length Calculators and Selecting Spokes
175mm crank of love
Good morning everyone,
Im buidling up a set of wheels (first time).
I have a spoke tension gauge, wheel truing stand and spoke wrench to do the job.
I have done all the measurements and run them thru a couple spoke length calculators.
They say "..these are maxium lengths..."
How accurate do I need to be when buying the spokes since not all sizes are available?
If I need
299.9mm front
296mm left and 295mm sprocket rear
Can I buy a bag of 299mm and 295mm spokes?
How far can I go from the original measurement? 1mm down, 2mm down? 3mm?? or up?
If I need
299.9mm front
Decrepit Member
I'd do as you suggest; 299s and 295s
The problem with going longer is that you run the risk of the nipples bottoming out of spoke threads before achieving adequate tension.
Bikes: 2006 LeMond Croix de Fer, 2005 Kona Dew Deluxe
Don't to hijack the thread, but on the subject of manually cut spokes - is it just me or are the manufactured ones a lot smoother? I just laced up a wheel with DT comp DB spokes out of a box and they threaded effortlessly into the nipples.
Liked 7 Times
When using double butted spokes I round down an extra mm on the driveside rear. But it also depends on how you calulate the lengths. The DT Swiss calculator automatically rounds down an additional mm for the DS rear if Revolution spokes (2.0-1.5-2.0) are used.
Al
Al
