Smaller cassette - new chain?
The Weird Beard
I'll be moving from a 12-34 SRAM 9-speed cassette to an SRAM 11-26. Which chain would you recommend, and will I have to shorten it to accommodate the smaller cassette?
Yes, you will need a shorter chain. I have never tested this, but I have heard that you should replace the chain when you get a new cassette, unless the chain has just a small amount of distance on it. I'm not sure if this is true, just something I have heard.
Low car diet
Bikes: 2006 Windsor Dover w/105, 2007 GT Avalanche w/XT, 1995 Trek 820 setup for touring, 201? Yeah single-speed folder, 199? Huffy tandem.
Actually, if you keep the same derailleur on, you don't have to shorten the chain. Your drivetrain won't know the difference, it'll all be the same except it will just think you're not using the biggest few cogs. That being said, I'd shorten it anyway because there's no need for the extra length. Edit: Like SweetLou said, you should get a new chain if the cassette has a decent number of miles on it, otherwise the new cassette will wear faster to match the stretched pitch of the old chain. You can keep the old cassette and chain as a backup or sell them together for a few bucks. Oh yeah, and most any 9-speed chain will work, but SRAM will say their cassettes and chains work best together.
Low car diet
I use Sheldon's method: https://sheldonbrown.com/derailer-adjustment.html#chain
Wrap the chain around the largest chainring and largest cog (bypassing the rear derailleur). Find a length that is just long enough to connect (inner plate to outer plate), then add one full link (inner plus outer).
