Threadless fork STUCK!
Sir Fallalot
Quoted: 9 Post(s)
Liked 13 Times
I wanted to remove the fork and headset from this frame in order to store or sell them. Anyway...
I removed the headset cap. I removed the stem. And... nothing. The fork remained in place. I see that there is the plastic ring keeping the fork tube in the top headset cup/race, and the fork would not move no matter what I did. I tried to tap the top of the fork, but that didn't help. I would like to avoid anything destructive. Any ideas?
Low car diet
Bikes: 2006 Windsor Dover w/105, 2007 GT Avalanche w/XT, 1995 Trek 820 setup for touring, 201? Yeah single-speed folder, 199? Huffy tandem.
When I went to replace the fork on my MTB, the same thing happened (or didn't happen, that is). It looked like the plastic ring was wedged too tight between the steerer and headset. Tried tapping it with a rubber mallet, nothing. I too was afraid of damaging something. But then I got over my worry, lifted the front end, placed a piece of wood over the steerer tube and gave it a big whack with a hammer and it came out easily. This would usually be bad advice, but in this case, just hit it a little harder. Edit: If you clamp a stem near the top of the steerer before hitting it (obviously remove spacers and make sure there's at least an inch or so between the headset and stem), it will keep the fork from falling all the way out and possibly hitting the ground when it gets loose.
Sir Fallalot
Quoted: 9 Post(s)
Liked 13 Times
Thanks!
Low car diet
Same feeling I got, right after surprise and relief that I didn't break something.
Bikes: 88 Fisher Gemini tandem, 92 Trek 970, 07 Nashbar Frame, 08 Gary Fisher Paragon
I've seen some fork drop right out after loosening the clamp bolts on the stem, and then other seem to be a little tight like yours. Myself, I would rather see it a little tight than a little loose. Some of the wedge spacers pop out with little effort. I try and give them a little waterproof grease like Phils during my assembly process.
I have a plastic mallet that I use for wacking the head tube. Usually doesn't take too much of a hit. Just make SURE you have your other hand ready to catch the fork when it drops!
Quoted: 1572 Post(s)
Liked 643 Times
I once had one that refused to budge with the amount of hammer force that I was willing to use. I emptied a 16 gram CO2 cartridge onto the steerer tube and immediately knocked it loose with a only tiny tap from my plastic headed mallet.
