walmart bikes!
Spandex free since 1963!
Bikes: Cannondale Road Warrior 900, Surly Big Dummy, Electra Townie
Quoted: 8 Post(s)
It depends on how you define junk. You won't get a $600 bike shop bike for $200 at Walmart. They won't be the same quality. But for $200, they aren't bad bikes for kids, someone who doesn't ride much or for someone that wants a winter beater. You will have to go over everything and make sure the Walmart quality employee who built the bike didn't leave any bolts or screws loose.
BTW, most good brand name bikes today are built in China.
Quoted: 9 Post(s)
Liked 9 Times
a lot of them really are crap.... Many of them pack maximum "features" in trade for quality & reliability.
I did buy a wall-world bmx bike for my brother: coaster brake, no suspension, very simple, $65 and going strong 6 years later! so they can be just fine for their purpose.
Cheers
Cheers
Bikes: some piece of s h i t
I rode a kmart cruiser frame for years as a beater with no problem, but when the frame bent cuz i bunnyhopped a pothole it threw the chain, locked up the pedals, and ruptured my spleen with the handlebar.
Yeah i was in the hospital for 4 days and got billed 9800 dollars but its not like that couldn't have happened on an expensive bike... Ive broke a chainstay weld on a Trek frame before and that had to be at least a $400 bike. Didnt smash any organs when that one broke though.
CRIKEY!!!!!!!
Bikes: several
Quoted: 1589 Post(s)
Liked 687 Times
I have some recent experience with walmart bikes in the process of building this xtracycle inspired load-carrier bike out of a few dumpster-rescued x-mart bikes....
The first thing I learnt in stripping them down was that they are assembled with fairly poor quality components. Bolt heads and threads strip and round off with very little effort. Bearing surfaces are left soft instead of surface hardened. There is plastic in places where there really should be steel or at least aluminum alloy.
In the process of stripping down an almost new bike I found that they're put together very poorly, obviously assembled in a hurry. None of the bearings were properly adjusted or locked, and they had virtually no lubrication.
The frame welding is adequate. The frames are heavy but not strong, they're made of a relatively soft grade of steel. I was surprised at just how soft they are. Subsequently there's fairly thick walled tubing to compensate. The welding also looks to be the absolute minimum to hold these frames together and obviously done in a hurry. The ones I cut open had voids where the welds were done 'cold' and had not fused to the tubes, a fault caused by running the weld too fast. Thicker welds in this case give a much stronger joint, you can see the difference between my welds and the original welds here....
The situation isn't all bad, it comes down to just how you use the bike. If you just putter around occasionally at low speed on a local MUP then these bikes are OK. I suspect that 99% of people that buy these bikes do exactly that. If you're a dedicated commuter or car-free and heavily rely on your bike, and consequently are an above-average strong rider then I think you're risking serious injury on one of these bikes.
If you get one of these bikes I would suggest you take the time to completely strip it down to a bare frame and reassemble it properly. Lube all the bearings, set the preloads properly, replace bolts at critical points with high tensiles, and adjust everything as you go. I did just that on this project and now the components performs far better than on the original bikes.
My kids ride on these x-mart bikes after I stripped and rebuilt them (the bikes, not the kids ), but the oldest only just came off her training wheels and can barely hit 8 mph. As she gets stronger and rides longer distances at higher speeds she'll be on a better quality bike.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
^^^ supports my experience and arguments...If you plan to ride at all I would suggest getting a decent used "brand" name bike. I quite often suggest to people that they head down to my LBS, they usually have several decent used bikes for 1/3-1/4 of new that come with a 6 month warranty and free 30 day check up. I buy them on occasion. My last one was a 2003 Staiger that will have sold for over $750 new, I picked it up for $175. That bike came fully loaded with fenders, lights, racks, V brakes, air pump and a Nexus generator hub
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Sophomoric Member
My first bike, about 6 years ago, was an abused Roadmaster (Walmart, I believe) MTB that I bought used for $40--and that was overpriced. But it got me riding regularly and served me faithfully for 5 or 6 months. At that point I knew enough about what I was doing to buy a good used Specialized.
Too many beginners get hung up on wanting the "just right" bike. They worry so much about buying the wrong one that they don't buy anything at all. Ride something, it doesn't much matter what, as long as it fits you. Worry about getting the "just right" bike later, when you know more about what you're doing.
"Think Outside the Cage"
Instigator at best
Bikes: Motobecane Jury
I think wal-mart's bikes are sold almost exclusively to people who a)don't know what makes a quality bike, and b)won't be doing any riding outside of their local neighborhood. So really, they don't have any reason to produce a nice bike.
When bikes are made with cheap frames and cheap components, things will go wrong in a hurry. And if a bike is assembled improperly and not checked, it can result in ongoing maintenance issues. For anyone using a bike for commuting or day-to-day riding, the bike should be reliable and dependable. That's my only complaint about department store bikes.
There are some good bargains to be had in the local bike shops. An adult bicycle at a department store costs around the $200 mark. At a local bike shop, I can get something of a similar style but much better built for just over $300. If a bike shop carries used bikes, it's possible to get a lower price on a much better bike than the department store special.
wheelin in the years
Bikes: Some Schwinns, a Gary Fisher, some vintage lt wts
For what its worth:
I have been goofing with a Mongoose IBOC that was originaly sold at Target. I don't have more than 20 miles on it. (An aside I did not buy this bike, it was left over when a co-worker brought me 3 bikes to make two.) It riides OK but I have replaced these parts on it:
wheels
seat post (to short for the average adult male)
rear derailur
front brakes
Will be changing soon:
crank and chain rings
front derailur
So it rides pretty good and only needs a few things replaced. Oh I havent broken it down to see what is used for the bushings in the pivots. I don't expect them to last long.
wheels
rear derailur
front brakes
front derailur
Sophomoric Member
For what its worth:
wheels
rear derailur
front brakes
front derailur
wheels
rear derailur
front brakes
front derailur
Not much but I tinker with cycles alot. So I had all of it in the parts bins. If I would have had to even use Nashbar it would have exceded the cost of the bike new. So the idea is you would be ahead to buy a better bike from the start.
If you like doing your own work you can keep an eye out at the local charity thrift stores. This is the time of year when people donate. I know I have found some very sweet old road bikes for very little money.
Bikes: 60's lowrider, 80's Cavaletto Centurion, 94 Specialized Rockhopper sport
A good middle range go to a Dick's sporting goods type place, they have Diamondbacks for 200-600 and they really aren't all that bad for light use.
Quoted: 70 Post(s)
Liked 15 Times
Aaron
Immoderator
Bikes: Gary Fisher Simple City 8, Litespeed Obed
Some of the single speed cruisers would probably last a little while and be relatively trouble-free, but anything at that price point even attempting to have front and/or rear shocks, a triple in the front and 8-speed in the rear is going to be complete, grade Z crap. A couple people will inevitably disagree with this, but they are wrong.
Giant, Trek and others have plenty of fine entry-level stuff for just a little bit more money, and even better quality used stuff can be found in Craigslist or the paper. I say this not because I hate Walmart, but because I love bicycles. Friends don't let friends buy bikes from Wally World.
Pedaled too far.
Quoted: 11 Post(s)
Liked 7 Times
I've only bought one bike out of a big box discount store, Zayre I believe. The link has a nice ad for them. This link has Batman at Zayres It was a Royce Union 10 speed. The frame was fine, but all the screws were cheap and stripped within 6 months. I had one other bike from Montgomery Ward, another 10 speed that I got off my brother. The frame came apart two weeks after I started riding it.
I never bought from Walmart but I did buy a department store bike that I would say was half a step up. The store couldn't keep the BB running for more than a week without problems. I swapped it out for a cheap sealed unit. I broke the rear axle (twice) OK, that took a while. The frame gave up after a couple of years, cracking through at the seat post clamp. The paint was thin as paper.
However, it did good duty for 2 years, and for the money was worth it.
I now have a mid range older bike and have much more enjoyment out of it.
If you accept that what you are buying is mostly a bike shaped toy, then OK, It will work, but don't expect to get much mileage out of it without putting some more into it, and don't trust it till you've stripped and rebuilt ti.
But I expect more. If I'm buying a new item, whether a bicycle, computer, a piece of machinery or a tool I'll use, I want something that will work reliably. I've turned down so-called bargains because I wasn't convinced of the quality of the product. And if I buy something unreliable and it breaks down, I'll have to buy it again. In that case, I'll pay twice instead of spending a bit more to get a more dependable item the first time.
livin' the nightmare
Bikes: '81 Centurion SS coversion, other ****
One of the bikes I have is an aluminum frame "Schwinn" Prelude from Target. I've switched out the seat, handlebars, and levers, and added Power Grips to the platform pedals. I paid $150 for the bike, and about another $90 on the aforementioned accessories/parts. It wasn't put together too badly; I had to adjust the derailers and brakes, but everything else seems spot-on. It seems fairly solid compared to any other bike from xmart. I don't worry about it falling apart at speed, or anything.
I probably could have just spent a little more and got a "proper" bike from the LBS, but on the other hand I really don't see why this xmart bike can't be used to commute, even unmodified. The only thing that really needed to be changed was the seat (the stock one is awful), but everything else was basically preference. I've gone on 30 mile round trip rides with it, with no major complaints. I don't see why something of the nature couldn't be used for commuting, honestly, as long as you know enough about bikes to keep an eye out for problems. The things are built to a price, and I imagine they aren't as durable as many pricier bikes.
My first "adult" bike was a department store MTB. I actually rode it for a couple of years, but by the end of that time it was completely trashed. It was $115, which is $60 more than the very good '88 Mongoose Alta I got recently that is an infinitely better bicycle, and it was an entry level Mongoose in its day (which is far different from an "entry level" Mongoose today, I'm afraid).
For an example, my local craigs list has a Trek 800 listed for $80. By going to vintage-trek.com I can see the specifications. It was entry level when it was made but its frame is Cro-mo main tubes and nice rapid fire shifters. The frame was desighned to last a life time -so the warranty states for the original owner. It is very plain looking compared to the glitz of dual suspension and chrome glitz of the department store bike but it is good solid trasportation.
I got a schwinn crossfit from goodwill for 15 dollars, put 40 dollars of good new tires onto it, and swapped the seat and stem with ones i had at home, cleaned it and threw on some fenders.
So now i have this touring-geometry bike with 700c wheels for cheaper than a fugly huffy full-suspension walmart turd. the frame is made of hi-tensile steel instead of cro-mo so it weighs more than it should, but for 15 bucks i dont care.
But while I looked for a thrift store deal, i rode my moms diamondback hybrid to work and the grocery store for about a month. it got the job done.
Bikes: bianchi spillo
I agree, I used to have a mart bike when I was a kid. The brakes failed on the first day I rode it, and the gears wouldn't shift properly when they were supposed to, but sometimes did shift when I put more pressure on the pedals. Also, a mate of mine got a mart bike a month ago, and the crankset is stuffed already! He doesn't ride far, fast, or aggressively, either.
