Ways to stop being a masher
Bikes: Cannondale Furio Specialized Allez Pro
Liked 5 Times
I have a tough time stopping my mashing. I end up with my toes going numb sometimes. I was wondering if anyone here has solved this problem with themselves and could give me advice on how to stop this behavior.
My cassette goes to 11
Bikes: 2008 Trek Madone, Canondale T2000
I use a cadence monitor and and each mile remind myself to "make circles". Over the last three month, my average cadence has increased from high 60's to low 80's.
Gorntastic!
I've gotten lazy and turned into a masher. Sometimes it's OK to mash, but on a tough hill you want to be able to switch back and forth between both.
But you can build up your cadence by dropping a gear or two and focusing on rapidly spinning circles--pushing and pulling at the same time.
Try riding up a hill that you can't but spin up.
Of course mtn biking up some loose gravel will teach you to sit and spin.
Spelling Snob
Bikes: Panasonic DX4000, Bianchi Pista
on the fixie before buying a road bike.
The first rule of flats is You don't talk about flats!
Bikes: 2001 Giant OCR w/105-10spd, Schwinn High-Plains Built for Commute plus 3 Others in Various Stages of Rebuild/Repair
fixies are great, but not always a viable option for a new cyclist, if you can get one give it a shot, it has helped me significantly.
Cadence monitors help as well.
Look at your gearing, is it appropriate for the terrain and your ability?
Also check out clipless pedals or a good set of toe-clips, I found that higher cadences became much more comfortable after that.
Triathlon in my future???
Bikes: Junk, that is why I am here. :-)
I would buy a computer with the cadence built in. Learn to get your cadence up and save your knees the frustration. It is simple, and all you have to do is change your pedal strokes and pedal more often but easier. Shift the gears to make it work the way you need it to.
If your feet are going numb, either your shoes are too tight, or if you are not clipless, your cage might be too tight, but I doubt it. Move your toes around inside of your shoe while riding and that will help with the numbness.
2007 Jamis Ventura Comp
2006 Jamis Explorer 2.0
2000 Specialized Hardrock (bought used)
Swim, Bike, Run and sounds like fun
Out fishing with Annie on his lap, a cigar in one hand and a ginger ale in the other, watching the sunset.
Bikes: Techna Wheelchair and a Sun EZ 3 Recumbent Trike
Quoted: 9 Post(s)
Liked 22 Times
ride fast in the lower gears until it feels natural. If you start to bounce in the saddle, you're spinning too fast, A good rule of thumb is 1 1/2 rotations a second or a bit faster for a 90-100 cadence.
Crazy Train from Ozzy Osbourne is about 100 BPM, if that helps you with cadence.
. “He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.”- Fredrick Nietzsche
"We can judge the heart of a man by his treatment of animals." - Immanuel Kant
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
I used to mash and found it almost physically impossible to spin at 100 rpm. It rained for a long period one year (strange for SoCal). I think I was planning on doing a century as I was really worried about getting in the saddle time. I bought a trainer and read some of the workouts. One was a high rpm interval workout.
Each interval was doing a minute over 100 rpm concentrating on spining without bouncing. A few other workouts as well. When I returned to the road, my cadence was much higher and my speed had increased. I'd sit in a paceline doing 21 and notice I was the only guy in the small chainring (39t).
Now I have a triple and a double. My cadence is lower (80-85)with the triple as the middle ring is a 42. But my cadence really kicks up (95) when I ride the double as the ring is a 39. I really notice the high cadence really helps riding into the wind.
Bikezilla
Bikes: Co-Motion Mazama
Bikes: Old Bike: 1975 Raleigh Delta, New Bike: 2004 Norco Bushpilot
Liked 5 Times
Use a lower gear, or a lower range of gears. honestly the ideal is that you stick near 90RPM. this means if you hsve a bike computer, put it in timer mode, now count for 6 seconds, every time your right foot hits top dead centre. If your count is below 8, then drop down a gear, but stay at the same road speed. If your count is above 11, then shift up a gear, as your spinning faster then you really should, spinning too fast, causes the opposite problem, burnout. . After a week or two, you will find that your "cruising" in certain gears, now you know where you want to cruise.
Mega Clyde
I am working on this now as well. My natural cadence is around 65, but I am trying to increase it.
+1 on the cadence monitor. I got one w/ my bike computer for XMAS and it has been quite enlightening. I have started using a gear or two lower than normal and my cadence is now up over 70 in only five or six rides. My overall speed hasn't changed a lot, but I am still working through the process. Most of my rides are fairly flat so we will see how things develop.
Good luck and keep after it.
Liked 5 Times
The fixie is not going to happen. I own a mountain bike and I am currently building a rode bike. I did get a fixie workout last week when it was below O F and I could not shift either derailleur.
I am trying to decide on which cadence monitor to get. I last had a Polar and after going through three of them in three years I will never buy something from them again. I am currently looking at getting a Blackburn Delphi 5.0 I was looking at one at my LBS and it seemed pretty decent.
Last summer I had my cadence up to 80-90 for most of the ride and some short sustained burst over 90 for a while.
I guess I should have said that I use Crank Brother's clipless pedals. Sorry about omitting that.
Thanks for the advice everyone!
On my TARDIScycle!
Bikes: Trek 520, Trek Navigator 300, Peugeot Versailles PE10DE
Quoted: 5 Post(s)
Just force yourself to use lower gears. It will come natural after a while.
I kind of got a friend into riding about a year ago. He commented once while rode that he was perplexed by my riding style. I rode slower than him, with a faster cadence. He said I was slower, but steady....it seemed like I never let up. He would ride harder and faster, but have to stop and rest/coast for a while. Then at the end of a ride he would be pretty tired and I'd be mostly fine.
I tried explaining why lower gears was better than mashing and even pointed out his pains to create some validity, but he never did quite "get it". He couldn't understand why his "faster" riding wasn't better. Now he doesn't ride anymore....probably got tired of how tired and achy it made him.
Solo Rider, always DFL
Bikes: Cannondale T800, Schwinn Voyageur
Get a computer with a cadence counter (Astrale has made me happy, and they are cheap...)
Do cadence intervals (x seconds at base speed, x seconds at base +5 rpm, x seconds at base +10 rpm etc.).
Once you hit a point where you are bobbing/bouncing in the saddle, rest for a bit and start all over again. You'll get used to it pretty quickly...
What is the formal definition of "mashing"? As a newbie, I hear this quite a lot. I do most of my riding so far with a cadence of 90-95, if I can't keep that cadence, then I shift down until I can. Is that mashing? Thanks.
This might seem like dumb advice, but the best way to stop mashing is to stop mashing. If you find your legs grinding away at a slow cadence on flats and mild inclines, downshift to a lower gear. Concentrate on maintaining a high, steady cadence rather than a steady speed. If you're thighs & knees are bothering you, you are in too high a gear.
On my TARDIScycle!
Quoted: 5 Post(s)
Mashing is using higher gears and a slower cadence. You go fast, with slower (but requires more power from the legs) pedal cadence. They call it mashing because you are "mashing" with a lot of power instead of spinning more easily. Mashers often end up more tired and/or have knee problems after riding because of the overexertion.
Another thing that simulates this can be spin class bikes. Many of them use a very large flywheel fixed to the cranks so if you turn the resistance all the way down they will behave somewhat like a fixed gear. So that would be an option as well.
Liked 5 Times
I always thought mashing was when you used the down stroke of the pedal to create your power instead of the up stroke. When I took a spin class the guy would say it should feel like your feet are barely touching the pedals.
Nerd Rider
Sorry for the rant. I'm on a mission to drum out this idiotic myth that people need to spend a few hundred dollars to get a new crank.
Quoted: 9 Post(s)
Liked 22 Times
Tere are two definitions, depending on context.
- Yours
- powering in to high a gear at too low of a cadence
