Trekking Bars/Butterfly bar or U bar question
Support JDRF
Bikes: Specialized Sirrus, Specialized Roubaix Elite
Quoted: 52 Post(s)
I bought a trekking bar the other day and I don't really like it. I wanted more hand positions. I had a flat bar and didn't want to have to buy new shifters going to drops. Has anyone got any tips for using Trekking/Butterfly bars? It feels to narrow and makes my wrist bend.
I may try some U bars next if anyone has experience with them, I would like some advice.
Thanks
Thanks
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
You can mount "butterfly" bars with the opening up or down. I have also seen people but bar ends on them in various locations. I use an adjustable stem on mine with the opening down and it works for me.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Support JDRF
Quoted: 52 Post(s)
George,
Those are the same type of grips off of my flat bar. I may try that tonight. Do you have a side view I would like to see what angle you have the bar mounted at.
Thanks
Thanks
The trekking bars of from Nashbar and the stem is a RID 130mm with a 30degree rise. The front of the bars are level with the saddle and the rear is an inch lower.
George
George
cycling fanatic
Bikes: Cannondale T800
Quoted: 14 Post(s)
I like your setup, George. I rented a bike in Austria in October and the bars were set poorly. Whether my hands were on the upper or lower horizontal made little difference to my body. One nice thing about trekking bars is that you can rotate them to get an optimum variety of hand positions.
Support JDRF
Quoted: 52 Post(s)
Thanks,
Maybe I won't give up on them just yet. I will play with the angle a little more and put the grips on.
Sweet ride by the way. Both of you.
Cycle Dallas
Bikes: Dulcinea--2017 Kona Rove & a few others
Quoted: 197 Post(s)
Liked 10 Times
I installed mine with the opening away from me. I also used aero brake levers and mounted them like you would on a mustache bar.
https://www.bikeforums.net/showpost.p...8&postcount=39
I waited for a while before I decided on how I wanted the stem. I knew I wanted to get the bars out farther, but I didn't know how far. I when with the 130mm stem and now I can put my elbows on the grips and my forearms on the front of the bar to get a more aerodynamic position. Good luck, I think if you play around with them a bit you'll like them. When you put the grips on you'll have to give them a good push , but they do fit, as you can see.
George
George
Bikes: 92 Bridgestone xo-2 Turner Sultan
Quoted: 47 Post(s)
George
I don't want to get this thread off track, but how do you like the Coda and have you ridden it fully loaded ?
I know the factory in California still had some 2005s still in the warehouse and if you went to the right shop they could get you one. I got mine for $900 and I'm very pleased with the bike. I know the LBS would want to sell a 2008 for the profit, but I would try and push for the 2005. This year they cut back on there steel and went back to 531. On the 2005 the TT is almost level, I think it's about 1/2 lower in the back. If you wanted to put a steel fork on it, that would cost around $70, but again, I'm pretty happy with just the way it is. Anyhow good luck and have fun riding.
Oh, I forgot I wrapped the bars with a double wrap of gel tape, no vibration at all.
George
George
Bikes: Surly Pacer, Trek 520 & gaspipe fixed gear beater
Hey George, nice looking set up with those bars. I put trekking bars on my wife's bike. She doesn't ride very much, but she didn't like the flat bars when we did some longish rides.
She's happy with the trekking bars now, but I'm always wondering about brake access. When I ride drop bars with crosstop brake levers, I can brake from any hand position. On trekking bars, you can only brake from one position. Do you find that that limits your use of the other hand positions when riding in traffic?
Bikes: Rodriguez Toucan tandem, Rodriguez Rainer Lite sport/touring
These trekking bars are kind of interesting: https://www.wallbike.com/oddsnends/selego.html
I wonder about the breaking issue, too, though, and I'm considering trying an in-line break set-up that will give me access to breaks from at least two hand positions. As it stands I often have to switch hand positions to stop or sometimes ride with one hand forward and one back, so at least one hand can reach a break easily.
Mine have the open end facing front. I put the grips from my flat bars on them (had to slice off the capped ends), and I got 4 Nasbar gel strips which I put on the other two most likely hand positions before wrapping the whole thing up with tape, which seems to do the job, although I think it might be a little better to actually have two more sets of grips on the bar.
Formerly Known as Newbie
George, is that an Ortlieb handlebar bag mount there? Did you have any difficulty fitting it? I might need to try out the butterfly bar myself, but eyeballing the few that I've seen on shelves around here, I'm a bit cautious regarding the handlebar bag.
--J
--J
To err is human. To moo is bovine.
Who is this General Failure anyway, and why is he reading my drive?
Become a Registered Member in Bike Forums
Community guidelines
I put a 130mm stem on so it pushed the bars away from me, where I can just use the grips all the time if I feel like it. When riding into the wind I put my hands on the front of the bar. If it's really blowing hard, I put my forearms on the grips and leave my hands hang over the front.
I got the handlebar bag from REI, I think it's the biggest one they sell and it was around $65.
I have tights now and they are much better than sweat pants.
George
George
I had the shorter stem on the bike and had them tilted down a little more when I took this picture. You would be surprise how much that changed the feel of the bike, when I went from a 120mm to the 130mm.
George
George
Bikes: Giant OCR2, Puegeot Altitude 21 MTB
Nice bars George!
What kind of grips are you using near the shifters/brake levers?
Ed
Ed
Bikes: Xootr Swift, Dahon Speed P8, Jamis Aurora
I just ordered butterfly bars for my folding bicycle (a Downtube 8H) to make it more suited for long rides and touring. Should I have the handlebars mounted with the bar ends pointing towards me of facing away from me? I would think having the bar ends facing away from me would allow for a more stretched out, aerodynamic position (which I want) but I don't really know. Any advice?
Oops, what I meant is whether the bar ends are facing the rider (as in an M) or facing away from the rider (as in a W). It looks like George has his bars in the M position.
I will have my LBS do the installation (not being very mechanical). If I opt for, say, the M position and decide later I want the W position, is it simply a matter of loosening a few bolts and rotating the handlebars, or would it be more complicated due to the cabling?
Quoted: 598 Post(s)
Liked 283 Times
No big deal to turn them around and reorient the brake levers and shifters. The cable length most likely won't be a factor as long as the LBS leaves enough for that in mind. If you do go the other way, you might need to cut down the cables and housing but as Sheldon would always say, "You can't cut longer"
