MPH Hydro problems. Help needed.
XtC Addict
Bikes: Giant XtC SE3 Bianchi Gold Race 600 Triple Barracuda Overload
The other day i was washing/cleaning/lubing my bike, and some of the lube got onto the rotor and brake pad, now the brake performance is downright lousy. I scrubbed the rotor, and sprayed disc cleaner onto the pads, and tried to run em in, but nothing, sprayed em with water, ran them again, watered, ran em, NOTHING.
They still drag, but locking them is impossible, which is annoying as im practising trials stuff right now.
What i want to know is how the hell to get the pads out? There are two large bolts and a small bolt, i think its holding the two halfs of the caliper together. The small bolt is stripping, and i dont want to ruin it before finding out if its the right thing to be doing. Is that how to remove the pads or is there an easier way?
Also, what do i do with the pads to rejuvenate them once they're outta there, i remember someone saying about baking them ! I also read in a mag, that disc cleaner should work with a good scrub with wet+dry sandpaper afterwards.
Cheers for the help
Cheers for the help
Bikes: Lots
What kinda discs are they? MPH? Never heard of them, maybe I missed the boat of something today. If you got lube on the pads, they're contaminated for sure!
I'm not sure what you can do. You COULD try baking them. Remove the pads (as soon as you figure out how!) and place them on a baking sheet (with foil) and set them in the oven for 20 mins at 250 degrees. I tried heating a set with a propane torch, but they got too hot and the glue holding them to the backing plate melted and they crumbled!
L8R
L8R
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, What a Ride!" - unknown
"Your Bike Sucks" - Sky Yaeger
Donating member
Originally posted by a2psyklnut
What kinda discs are they? MPH? Never heard of them, maybe I missed the boat of something today. ...
L8R
L8R
Currently riding an MTB with a split personality - commuting, touring, riding for the sake of riding, on or off road :)
Bikes: Lots
I was just doing some reading over at RideMonkey, and there are numerous suggestions, here's a link:https://www.ridemonkey.com/forums/sho...d&pagenumber=1
I'm gonna try the boiling in water and detergent on a set I have and see how that works. Meanwhile! I've got a new set of pads on order!
L8R
L8R
XtC Addict
Id upload pics but i cant find any/dont have digicam.
Cheers for the help, theyve been gradually getting better, but they still dont have the `bite` i want
XtC Addict
I took the pads out* and took a blowtorch to them, then i took a rough piece of sandpaper, and took the layer of charred rubber/metal from the top. I scrubbed the rotors as well with the sandpaper, and now its all reassembled, they are much better, they are still not as fresh as when i first used them, but they are seriously more powerful.
*The small bolt was the damn one holding in the pads just typical.
XtC Addict
While on the subject of discs/pads, does anyone know what the difference between sintered and normal pads are?
Cheers for all the help.
Alcohol, Isopropyl alcohol to be exact.
Rub down the pads and rotors.
I torch my pads, and have never had a problem.
For replacement pads, get EBC Gold pads. Best pad's made IMO.
