Platform pedals and brakeless
Playing with the traffic
Bikes: 2009 Colnago Primavera, Campy Chorus 11 speed, 1986 Colnago Master, C-Record, 2008 Surly LHT, 1930's Malvern Star 3-speed.
Basically, how's it done? I'm totally baffled. How do you stop, except by scuffing the back wheel?
Please enlighten me.
ALL PARTY
Bikes: Douglas Touring Cross Wise, Urbanite Fixed Gear
Skip and skid? If you're oblivious on how to do it: Put your weight forward on the bike (I usually put my chest basically on the handle bars) and use your right leg to push completely back. You have to have the right timing to do so, so wait for your right pedal to be at 9:00 and your left at 3:00. Push as hard as you can on your back pedal, and your wheel should lock up. It takes a few tries, and is easiest to learn the motions on snow, ice, or a wet road.
ALL PARTY
I did it for a while (platforms, I still had a front brake just in case) and sort of liked it more than the clips I have. Mind you, my clips are cheapys with plastic toe parts, and nylon straps. I only payed like 19 dollars for them, though.
The only difference is if your foot slips, your feet come off the pedals and you eat ****, badly. It happened to me and I switched to clips.
Run What 'Ya Brung
There are lots of people who claim that they can skid "just as well" with platforms, but I suspect that "just as well" for these people means getting their cranks in the right position, and putting their entire body forward, whereas the rest of us (with pedal retention systems and a modicum of skill) can skid with their feet in almost any position without leaving the saddle.
ALL PARTY
I need to masta the sit down skidz. I can do them on snow and ice, and occasionally on slick wet pavement, but still not skidzorz enough to do it on dry pavement.
This is OT to this post, but someone explain that **** to me again, some guy just said 'flex your ankles', but I'm not sure how to position my body. Do I put extra weight on the front still? or?
Ride for Life
do you wanna know how to stop or how to skid? when i ran brakeless and platforms, i ran 42x16, didn't go fast and i slowed down early, there was rarely any skidding involved. you can't be in a hurry to get anywhere or you're gonna get screwed.
as for how to skid, put your nuts (or vulva, ladies) on your stem and lock one of your legs so that it's in line with the crank.
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 25 Times
So who's going to be the first to say that skidding and skipping and all these other hipster tricks is suboptimal braking on a brakeless...?
Run What 'Ya Brung
It's not about optimal braking, it's about emergency braking. If you can't skid stop your bike on a moment's notice, you shouldn't be riding without brakes.
"this is not suck"
ok sit down skids: the way I figured this out was: I stiffen whichever leg, as that pedal is coming upwards, I let the pedal lift me slightly off the seat, and this completely unweights the rear wheel, and it's easy to lock it up from the
seated position or just skip it and do the same thing again as the other pedal comes around, THAT stops you going down hills WAY better than just skidding.
(theres probably a name for it, but I'm ignant )
I used to do "jamaican skids, mon" (I was told this trick here) where you hook your foot under the front pedal, and then push back on the rear, but if you run cage pedals like I do, your going to need a new pair of shoes each week, as the shoe tops just get cheese grated.
ok I HATE CLIPS,...or thought I did,..THEN I got some GOOD track pedals with steel clips, and GOOD leather straps (soma hellyers, no name clips, soma double straps), and they are just so natural and easy to kick into (you don't have to look 95% of the time) now I don't mind the clips so much, in fact I'm gettin to kinda LIKE IT as now I don't have to lug around a pair of walking shoes (I tried running clipless for a while too)
this is what got me hooked on riding fixed, I had to "learn to ride" all over again
Run What 'Ya Brung
Cornucopia of Awesomeness
Run What 'Ya Brung
It certainly takes me longer to slow my track bike from speed (say 17mph or so) to a stop by simply resisting the pedals than it does to skip or skid stop it. Obviously a brake is how one should stop their bike, but we've removed that from the equation.
My local store wrench in Vancouver sent me out to try out a brand new, blinged out $2000+ IF tarck build he had just put together. It had no brakes, clips or straps, and this was my first time riding a bike set up in this jackassed fashion. Needless to say it was sketchy. I was pretty ****ing careful but i did try a few "jamaican style" skids.
cab horn
Quoted: 42 Post(s)
Liked 25 Times
The same principles apply to braking on any other wheeled vehicle. Do I really need to further prove that maximum deceleration is acheived by not skidding tires?
P.S Name-calling is against forum rules. Thanks
stay free.
Bikes: EAI Bare Knuckle, 1980's Ross Signature 292s 12 speed
Let me help educate you: https://en.wikipedia.org/wiki/Anti-lock_braking_system
Bikes: bomber pro
Why in god's name would you want to ride fixed without clips and straps, or clipless?
Someone give me decent answer for this...
cab horn
Quoted: 42 Post(s)
Liked 25 Times
Skid stopping, skidding is not optimal and you are doing everyone a disservice by telling them that these are good "emergency" braking maneuveurs. Anyone who has taken high school physics or a basic driving course will have learnt this. Every racecar drive in the world knows this as well.
Convenience, or perhaps ignorance.
"this is not suck"
That is an incorrect intrepretation. Maximum deceleration is achivied with rubber firmy planted on pavement and with the wheel JUST at the point of lockup (but not locking up). ON a brakeless fix, if the rear wheel is off the ground then it is providing NO deceleration as long as it is there.
so while the wikipedia regurgitation, and the racers braking physics lessons ALL apply, they don't work when you ride a fixed gear bike down a freaky scary steep hill like 21st st in san francisco (from the top,heading east, down to mission), even with a front brake, I skip it every half block or so, just to keep the speed down.
we now return you to the regularly scheduled rock throwing contest.
