SRAM X9 high or low clamp FD
Caustic Soccer Mom
Quoted: 11 Post(s)
what's the difference? Want an X9 for a C'dale Taurine (26" ht) AND DON'T KNOW WHICH TO GET.
As with mud, life, too, slides by.
Lost in the Black Hills
i am pretty sure you need top pull high clamp. my sram x9 has been working great! don't forget to order a spacer if you need it for the frame.
Tomac Mountain Bikes | Light-Bikes l Magura USA | Industry Nine | Schwalbe Tires | Caffélatex
fine. next time i won't help.
here is some more advice: google
Caustic Soccer Mom
Quoted: 11 Post(s)
sorry, mx - it was the "I'm pretty sure" that makes kind of want confirmation. I did google, and it appears that it's such a little detail no one bothers to make a distinction....
it looks like it is a high mount as well. like my hard tail
because the low mount looks all f@#%@# up
Still kicking.
Simple, get an xt one and be done with it.
Appreciate the old bikes more than the new.
Quoted: 98 Post(s)
I'm guessing high clamp.
The XT that I have is a much lower clamp than that one. If this still doesn't help, buy both and return the one that doesn't work.
Official Website Waterboy
Bikes: a lot
I've found the top swing, ( or "low clamp" as it's known in this thread ) to be the more universal of the two, as the bottom swing ( or "high clamp" ) sometimes can have issues with shock mounting, or bottle cage mounts.
Guest
Posts: n/a
Quoted: Post(s)
Thanks for the answer. I was assuming it was something like that but wanted to be sure. I have no bottle cage mounts to get in the way so I guess the safe bet would be to go bottom swing although is there any advantage (weight / quality / durability) of going with a top swing?
Bikes: a lot
Some bikes have shaped tubing at the joints, or pivots for suspension that could render a
top swing useless. I can't say that there is a set weight advantage or reliability
advantage to one specific design.
Caustic Soccer Mom
Quoted: 11 Post(s)
thanks. folks... just found a high clamp top feed 31.8 x9 for $32.99
cool!
mx
mx
