What is this green stuff coming out of my fork?
2-Cyl, 1/2 HP @ 90 RPM
Bikes: 04' Specialized Hardrock Sport, 03' Giant OCR2 (SOLD!), 04' Litespeed Firenze, 04' Giant OCR Touring, 07' Specialized Langster Comp
I aired up my fox float RL up to 100psi today (my recommended is 70), didn't like the way it felt, and I went to let the air out to start over, when i did, about 2 drops of green fluid sprayed out of the air valve. Aside from that, everything seems to be working a-ok right now.
What was that??
What was that??
Look at all these buttons
It coulda been the shop grease. We used to use grease that was all green (I can't think of the name now tho)
I wouldn't think that it should be used on ur fork though... but I've never done a build or rebuild on a fork.
Nitro
Bikes: Salsa
Parktool Polylube? Thats what we used at the shop I worked at. It was green.
Bicycle Rider & Mechanic
Bikes: Superlight, Dragon Team, Eclipse, Om Flyer
haha
Don't listen to those idiots, It's float fluid in the air chamber. A little bit escapes when the schrader valve gets depressed. It's perfectly normal.
Old School Rad
Bikes: Blur LT
Monster Energy drink. Every good fork has a little in it.
Like a circus monkey on a stolen Harley......
haha
What made you jump to conclusions that it was polylube inside of the fork?
No worries...
What the hell do I know anyways... I wear a goddamn parachute when I fly!
World's slowest cyclist.
Bikes: Cannondale CAAD5 and Cannondale Rush
My fox rear does the same thing. When new it had a bunch of gunk in it, now it's reduced.
Its most likely slime, if you ever pumped up your tires with your shock pump it probably "inhaled" some slime from the tires then got blown into the fork and came back out after it settled to the bottom, same thing has happened to me. Perfectly normal, if its an air suspension fork it may be best to turn the bike upside down so that the oil that is supposed to be in the shock is not being lost and sucked into your pump.
Old School Rad
Bikes: Blur LT
So you pump up your tires with a shock pump?
Old School Rad
Bikes: Blur LT
Old School Rad
Bikes: Blur LT
Well, do have any pics to prove you ride?
Nitro
Bikes: Salsa
[QUOTE=elf 232;6309018]What do i seem clueless to you about? I know almost everything about bike building maintenance and repair, and have been completely correct in every one of my answers.
QUOTE]
That's not impressive at all. I can build and maintain a bike. I'm even good enough to be hired at a bike shop
QUOTE]
