Crank just spins?
who stole my bike?
Bikes: the black one from spin class
Crank just spins?
Okay I did a search but couldn't find the answer.
My crank is just spinning. If I move it real s-l-o-w then it will lock in and I can pedal again .. but once it freewheels then it no longer grabs again and I'm just spinning around with no power.
What do I tell the bike mechanic so I don't sound like a total noob?
Bikes: 2011 Lynskey Sportive, 1988 Cannondale SM400
Quoted: 20 Post(s)
Sounds like the pawls in your freehub or freewheel are stuck.
who stole my bike?
hey thanks a lot...i didn't even think about the hub...did a quick google and found this guide on cleaning it
https://www.parktool.com/repair/readhowto.asp?id=45
Quoted: 114 Post(s)
Liked 119 Times
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Left to it's own devices, a crank should just spin. It's the other stuff that keeps it from spinning.
Bikes: Iron Monkey: a junkyard steel 26" slick-tired city bike. Grey Fox: A Trek 7x00 frame, painted, with everything built, from spokes up. Jet Jaguar: A 92 Cannondale R900 frame, powder coated matte black with red and aluminum highlights.
A pawl could have shattered, too. If flowing stuff through there doesn't degunk it, open it up and look. If you find no pawls but lots of shrapnel, that's what happened.
Pedal pusher...
Bikes: I've got a bunch...
Quoted: 5 Post(s)
Hey that happened to one of my bikes and all I had to do was lay the bike on it's side and run some oil into the freewheel. I guess that was enough to free up the pawls...
surly old man
Bikes: IRO Mark V, Karate Monkey half fat, Trek 620 IGH, Cannondale 26/24 MTB, Amp Research B3, and more.
Quoted: 46 Post(s)
Liked 42 Times
Just be careful when you clean out the freehub to try to avoid letting the oil/wd-40/whatever getting into the hub. Grease does not like that stuff at all. It can be done on the wheel with care, but seems like it is much smarter to pull it so you can clean aggresively.
jim
jim
Cross Check Nexus7, IRO Mark V, Trek 620 Nexus7, Karate Monkey half fat, IRO Model 19 fixed, Amp Research B3, Surly 1x1 half fat fixed, and more...
SB forever
SB forever
