Help
Help
So, I riding next to a trolley track. Glance back and my wheel gets stuck. I didn't fall. But when I start riding again there is resistance. Kinda like a flat but without sloppy handling. I keep on riding and it goes away. I go home and flip the bike and there some noise coming from the bb. I wondering if this is ok. If you could not tell from me getting caught in the tracks I am a beginner.
Thanks in advance.
Thanks in advance.
Spelling Snob
Bikes: Panasonic DX4000, Bianchi Pista
Its hard to tell. Most BB problems are caused by direct force onto it (pedals)
If terrain that the wheels touch were to have a damaging effect, you would have
to have tremendous force pulling the chian backwards against the chainring.
Im sure something like that would have caused a fall.
Also: Never ride paralell to any kind of tracks. You were very lucky this time.
The first rule of flats is You don't talk about flats!
Tell them I hate them
Bikes: Specialized Allez Epic '91, IRO Mark V Pro, Schwinn Traveler
I think your wheel is rubbing the frame somewhere. Probably the chain stay right by the bottom bracket
simply krafting.
Bikes: 53cm Mercier Kilo TT Special Limited Edition (Black/Chrome)
Check your back wheel to see if it has been misaligned. If its even the slightest bit crooked, youre gonna have weird chain problems and rubbing. I would venture to say its probably a simple fix...
Thanks for the help
I checked the trueness of the tires and the straightness of the chainline, and everything is fine. So, I am assuming everything is good. Also, the noise from the bb was probably the normal sound from new bearings .
Look down your seat tube. Notice the 4 tubes that run from your seat tube to the back wheel. Is your rear wheel pressing against any of those (or has it left a skid mark on them?)
Also, you can try looking at the nuts holding your wheel on and check if they appear like they recently distressed some paint by sliding forward/back, that'd be a sign your rear wheel moved as well.
Your BB shouldn't make new bearing noise if it didn't before your wheel got stuck.
And just for your own info: your wheels, rims specifically would be what gets trued. Your tires are just that, the rubber part. Not trying to be a jerk, we all gotta learn somewhere.
The rear nut may have moved. I will loosen them up and re tighten them.
I know the rims are whats true but I was looking at the tires to check.
Edit: I have done this and it sounds smoother overall. Thanks again everyone.
