Mystery unusual English Lightweight needing ID. Pics!!
Viscount
Bikes: Mercian, Viscount x2, Holdworth La Quelda, Gundle Trade Bike, Williams/Mercian Tourer, Itera,
Just found this lovely mystery lightweight machine, probably late 60s.
No badges/decals to indicate make, but has good mid range components and in good working order.
Rode it for 10 miles or so yesterday to bring it home and it works perfectly.
Looks original and little used, and spec as I know it now is:
GB stem and Coureur calipers.
Ornate lugs!
5 speed with Atom flip flop hub.
Bayliss Wiley BB with oiler nipple.
Steel wheels, Huret derailer/changer.
Italia saddle.
Blumels lightweight guards and reflector.
Obviously from a small maker, probably Coventry made.
The triple triangle fame is quite distinctive.
(Did GT copy this??)
Cleaned up/lubricated a little from how it appears here and it rides very smoothly.
Ornate lugs!
Italia saddle.
feros ferio
Quoted: 1393 Post(s)
Liked 1,325 Times
Late 1960s or late 1950s/early 1960s?
Bikes: Cinelli, Paramount, Raleigh, Carlton, Zeus, Gemniani, Frejus, Legnano, Pinarello, Falcon
Quoted: 12 Post(s)
Liked 8 Times
That is very cool, 50s I'd say from the look of the lugs and the fork. The parts may be newer than the frame. There was a company that popularized that seatstay treatment, but I'm drawing a blank right now. I think Hetchins made them too.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
The BB oiler suggests a date in the early 60's or earlier. The fact that the oiler is the same color as the frame suggests a rattle-can respray. You might consider wiping at it with some Goof-off, see if there's anything left of the original paint and decals.
What's the seatpost size? That may tell you something about the frame material.
Bikes: 1 trek, serotta, rih, de Reus, Pogliaghi and finally a Zieleman! and got a DeRosa
Quoted: 15 Post(s)
Liked 9 Times
yup, hellenic seat stays. They were a very well known feature of
Hetchins frames, although not exclusive of them. I find 3 marques on
CR that show hellenic seatstays. Hetchins, Merlin (in Bob Jackson era) and
Thanet. The Thanet Silverlight had a strange offset bottom bracket so I don't think
that's it.
Most of the Hetchins I've seen had more elaborate lugs, and that is more elaborate than
the Italian style lugs.
By process of elimination I'd say probably a Merlin, 1960's at the latest.
Of course this is wild assed conjecture on my part, I do suggest you try to
get in touch with Hilary Stone about this one (he sometimes posts here but most often
hangs out at CR list.)
Marty
that's it.
Marty
Sono più lento di quel che sembra.
Odio la gente, tutti.
Want to upgrade your membership? Click Here.
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
^Yes^ contact Hilary or Norris Lockley (also of the CR list), they should have some help for you. I hope that isn't a crack in the BB shell near the oiler! Let it be dirt...
Bikes: 2 Cannondales and a Motobecane frameset
I am showing my ignorance but what is the CR list? Thanks, George
Bicycle Repair Man !!!
I haven't got a clue what it is but it is certainly, gorgeous.
Cr is Classic Rendezvous
Quoted: 15 Post(s)
Liked 9 Times
I was wondering why they were called hellenic seat stays then I stumbled across this
'Hellenic stays were introduced by (and named for) the British frame builder Fred Hellens in 1923'
on Sheldon Brown's web site (should have known the answer would be there).
marty
marty
very nice indeed!! you have yourself a real find there, I would not think of parting with it if its your size. Sorry no new info, what i knew has already been brought up but good luck!
Viscount
Thanks for all that guys.
I thought the best place to start was right here.
Bought it Saturday and only got it home late Tuesday, so not had time to do much research myself yet.
Got a few more specific details now I've had a closer look.
Seat-post is 27.2mm.
Atom hubs (Diana f/w) are inscribed 23 79 front and 08 79 rear. Might be dates?
Rigida Superchromix rims which are inscribed 37 + 79 in the diamond.
Looks like the wheels are 79 to me.
Probably replacements since the frame seems quite light without the steels.
Chain-set is Bayliss Wiley and stamped as here.
AX and AW seem to be date codes.
Headset is stamped Alatet.
New one on me!
Does look as if it has had a repaint at some point.
The seat stays are quite sophisticated being double tapered, thinner at either end.
Not seen that before.
Next step is to check Hilary Stone and maybe Classic Lightweights.
https://www.classiclightweights.co.uk/
Unfortunately the frame is a little small for me at 23" so it'll probably get passed on eventually.
New one on me!
Viscount
After ten minutes on the Classic Lightweights site I now believe it is a Pollard!
https://www.classiclightweights.co.uk...s/pollard.html
Viscount
How much you wanna put on it?
I would love it to be a Hetchins, but it ain't!
But it's probably rarer than a Hetchins...
Bikes: '39 Hobbs, '58 Marastoni, '73 Italian custom, '75 Wizard, '76 Wilier, '78 Tom Kellogg, '79 Colnago Super, '79 Sachs, '81 Masi Prestige, '82 Cuevas, '83 Picchio Special, '84 Murray-Serotta, '85 Trek 170, '89 Bianchi, '90 Bill Holland, '94 Grandis
Liked 12 Times
Alatet headsets are fairly common on British lightweights from that era; I have one that's going on my Flying Scot.
Liked 12 Times
Viscount
I was assuming, from the above pics, that it was a Bayliss Wiley chain-set.
If it is a Williams I stand corrected
The B W in the stamp led me to assume Bayliss Wiley obviously.
But this is how you learn and it's a newish area for me, so BF does the job again!!
If it is 1956/7 that fits in with the serial number which seem to run in series.
1898 was the last in 1990 and mine is 1596.
Adds up, and fits in with the Coureur brake set and mudguards!
The Alatet headset is free and smooth so I don't intend touching that.
Seems like I know the make and year 24 hours or so after posting the question here!
How good is that?
Thanks again.
P.S. Is your Flying Scot featured here on BF?
Be good to see it.
Viscount
Just to finish this old thread with the right answers....
It is a Pollard, made in Coventry in the late 40s!!
A beautiful and rare machine.
See here the brother of the person I sold the frame to riding a similar Pollard hellenic in competition in the late 40s.
I sold the frame and forks to a certain Peter Brown for a very modest sum. (£75)
When he received it he complained that I had not included the brakes and stem etc. etc.
Not an amicable transaction.
But it taught me lessons which are well learnt now
IE Do your research. Do your research. Do your research.
Wiser now
Should've kept it though.....
Wiser now
Likes For viscount:
Viscount
Just looking through old posts and realise that this one didn't get finished properly.
I think it could do with a final picture.
Pretty much original except for Huret RD saddle and later Wiliams chainwheel.
Rear Blumels guard was being fixed when this photo was taken.
It is a lovely, distinctive, English lightweight made in Coventry by a relatively unknown, small maker.
It was found languishing in a shed less than a mile from where it was made.
(Even on the same road. Stoney Stanton Road, Coventry.)
Now being restored by its new owner and will probably lead a pampered life from now on.
Should never have sold it....
Likes For viscount:
Liked 12 Times
How bizarre: I was just looking at this one on ebay yesterday:
https://tinyurl.com/dk6htv
and reresearching the whole Hellenic stay thing (though this one currently listed doesn't have them. There's yet another one (frame) on ebay UK right now. Maybe one of them has your name on it.
Viscount
That is a loooong shot!? And quite bizarre as you say.
These machines are ultra rare here in UK so how that one got over there is another story.
Doesn't look too expensive at $750 though.
Track frame too, admittedly a late one.
Still hens teeth stuff though.
The one on ebay looks a bit of a mess IMO.
The extra rear struts make it look as if the the rear triangle wasn't up to it in the first place.
The Hellenic version is the one to have.
I've only ever had, or even seen, two Pollards.
The other is here:
https://flickr.com/photos/bikesruz/
The other is here:
