Campy cable stops?
Campy cable stops?
I've got a set of these on my 76 Motobecane and I'm having problems taking them off. I can get them unscrewed easy, but I'm scared of bending them in the process of getting them off.
Anyone got any tips for me?
PS, they look like this.
https://cgi.ebay.com/VINTAGE-CAMPAGNO...ayphotohosting
FalconLvr
Bikes: 62 Falcon, 58 Raleigh Lenton Gran Prix, 74 Raleigh Pro, 75 Raleigh Int, 75 Raleigh Comp, 76 Colnago Super, 75 Crescent, 80 Peugeot PX10, plus others too numerous to mention!
Quoted: 51 Post(s)
Liked 112 Times
Well, the rear cable stop is pretty thick stuff and you just spread it open enough to clear the chainstay at its narrowest part, then slide it to where you need it, careful not to scratch the paint! The cable clips are very thin and spread pretty easy. The cable router at the bottom of the down tube is a little harder, you have to spread it out very evenly and hope it does not start cracking the chrome finish before you get it open enough to clear the tube.
Good info, I thank you.
Let your bike be the tool
Bikes: '66 Raleigh Carlton, '70 Ron Cooper, '95 Bianchi CD'I, Zonal Frame with Xenon gruppo, Carbon Frame with Record Gruppo, Columbia Twosome, Terry Classic, Bianchi SX, Gravity SS/FG
Quoted: 338 Post(s)
Liked 314 Times
I've carefully bent mine out, taken them off, and replaced them several times without damage. Of course most of those times were when they were bicycle parts rather than valuable antiques.
Never try to teach a pig to sing...
Quoted: 3810 Post(s)
Liked 6,690 Times
I can add that I've broken a Campy cable guide by not bending it evenly when I was trying to remove it and thus creating a stress point. As much as you can, apply equal force from both sides as you bend it to clear the tube.
Neal
Neal
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
It also helps to put a single layer of tape (like black electrical vinyl) on the tube and position the clamp's sharp edges over the taped area so as to protect the paint when you slide off the clamp.
Done and done. Got the three on the top tube done with no problems, but that one back by the RD is going to be a tough little bugger to get off.
Thanks for all the info fellas!
