Go Back  Bike Forums > Bike Forums > Training & Nutrition
Danger's of Frequent, High Heart Rate Workouts?
Training & Nutrition Learn how to develop a training schedule that's good for you. What should you eat and drink on your ride? Learn everything you need to know about training and nutrition here.
Old 03-17-08 | 04:31 PM
Dangers of Frequent, High Heart Rate Workouts?
Is it useful/safe to do most of your workouts at 80% to 90% of your maximum heart rate? I'm trying to get back in shape as quickly as possible. My body is good at recovering quickly after an intense workout and my heart rate drops back to normal very quickly when I stop. The thing is that I sometimes feel a bit dizzy when I'm working out and for the rest of the day, my breathing becomes shallow. Aside from the difficulty of working out consistently when pushing your body like this, are there any dangers in high heart rate workouts? Is this the fastest way to get in shape? I also feel like I'm building up my mental toughness by doing this.
madprofessor100 is offline
Reply
Old 03-17-08 | 04:50 PM
Red Baron's Avatar
20 Anniversary
Bikes: Not enough
I visited my dr over this. He said the heart is just like any other muscle, it needs time to recover.
he advised me that after I work out, IF I feel syptoms during the day, its a signal its recovery time.
Harsest thing for me to do is to remember a recovery IS a training day.
Red Baron is offline
Reply
Old 03-17-08 | 07:09 PM
Machka's Avatar
In Real Life
Titanium Club Membership
20 Anniversary
Bikes: Lots
Before you continue the sorts of workouts you describe ... go to your Dr. and have a complete physical. Describe your symptoms in detail. Insist on an ECG, and possibly also the exercising ECG.
Being dizzy when you hit your max hr or near it is normal for me (and I also see red), but 2 minutes later I'm fine again, I don't continue to be dizzy after.
(BTW - I have heart issues and I go for ECGs on a fairly regular basis, just in case. It never hurts to have one.)
Machka is offline
Reply
Old 03-17-08 | 07:22 PM
kuan's Avatar
Twincities MN
Bikes: Fat Caad Lefty, Foundry Overland.
How long are these workouts? Unless you are in great shape already, you probably cannot sustain 90% for very long. You might be able to sustain 80% for a bit over an hour, but then you'd probably need a day of recovery.
They will, however, increase your VO2max such that you can probably sustain a lower HR for a longer period of time at a higher speed so those long 3-4 hour workouts, also known as LSD workouts, become possible.
www.marrow.org
kuan is offline
Reply
Old 03-18-08 | 09:41 PM
20 Anniversary
Safe? Well, it's probably safe.
Useful? Not really.
If you are looking to improve your aerobic fitness - especially when you're starting out - then spending a lot of time in your anaerobic zone isn't particularly effective. If you have low fitness, however, you will get better while doing it. Just not as fast or as easily if you work out easier and perhaps a bit longer.
Being dizzy is a sign that you are working out too hard, as is feeling lung weirdness when you're done.
If you keep doing this, you will plateau and find it hard to improve.
More information here:
https://riderx.info/blogs/riderx/arch...ecificity.aspx
Eric
2005 Trek 5.2 Madone, Red with Yellow Flames (Beauty)
199x Lemond Tourmalet, Yellow with fenders (Beast)
Read my cycling blog at https://riderx.info/blogs/riderx
Like climbing? Goto https://www.bicycleclimbs.com
ericgu is offline
Reply
Old 03-20-08 | 01:25 PM
Pat
20 Anniversary
Bikes: litespeed, cannondale
As mentioned above, it might be a good idea to have a physical that stresses the cardio side of things. Better yet, have a heart check up with a cardiologist.
There is a problem too. A stressed heart looks like a stressed heart. A physician can often mistake a heart's healthy response to intense aerobic exercise as the response of a heart to disease. So it is a good idea to go to someone who has actually seen some aerobic atheletes. Most physicians deal primarily with sick couch potatos.
You might want to vary your work outs some. Riding at such an intense level is painful. People tend to aid pain. If all of your workouts are painful, you will almost certainly give up doing them. It often helps to vary the bike workouts in duration and intensity and mix things up with some easy "joy rides".
Pat is offline
Reply
Old 03-22-08 | 01:40 PM
After a week of trying this out, I definitely know what you mean. I'm becoming extremely tired during the day and I feel like I'm putting in a lot of work and my leg muscles are just being uncooperative. Actually, I would say that the main problem is that the heart rate training zones are different for cycling. I almost always run in zone 5 and 6 when I'm running and I can hold it for an hour and do this six days a week. Not the case with cycling.
Here's a good chart for heart rate calculations (it's designed for cyclists): https://www.machinehead-software.co.u..._abcc_bcf.html
I also looked into the rumor that high heart rate workouts are somehow bad for you. There was once a time when it was believed that a lactic acid buildup was somehow damaging to your muscles...
Reply
Old 03-23-08 | 05:01 PM
Red Baron's Avatar
20 Anniversary
Bikes: Not enough
[QUOTE=Pat;6374701]As mentioned above, it might be a good idea to have a physical that stresses the cardio side of things. Better yet, have a heart check up with a cardiologist.
QUOTE]
You got to the heart of the matter here!!
When I first saw a cardiologist, I did so as I saw a 202bpm after getting off of a beta blocker med. He told me I was having a Heart Attack. I said No way - either look better or I want a 2nd opinion. I explained I had been training for a Triathlon. I had brought in my training records and he sat down with me. He told me of couch potatoes, and changed his attitute quickly. After further tests, he said all OK but- He them proceeded to tell me how the heart was a muscle and treat it as such. He changed my attitude, and I do now understand recovery time much better. If I get dizzy on day after a hard work out-, its a sign for me of overtraining.
Reply
Old 03-23-08 | 05:10 PM
crtreedude's Avatar
Third World Layabout
Bikes: Cannondale F900 and Tandem
My feeling is that it is better to ride at a comfortable speed for an hour or two than 15 minutes at 90 - unless you are going to be going for time trials. I know that I can hike or bike for hours without feeling it much the next day - and when I need to dig in, I have lots of endurance.
Build up and let the strength in your body keep pushing you. As you improve in fitness, you will being putting more force into your legs. But, give it time. You didn't become a coach potato over night, and you won't become Lance overnight either.
crtreedude is offline
Reply
Old 03-24-08 | 08:14 AM
fuzzthebee's Avatar
bzzzz
There is a world of difference between an 80% MHR effort and a 90% MHR effort. Also, you really should use zones based on "threshold" heart rate, not maximum heart rate.
https://www.performancetrainingsystem...ne_finder.html
fuzzthebee is offline
Reply
Old 03-25-08 | 10:51 AM
Carbonfiberboy's Avatar
just another gosling
15 Anniversary
Eric, above, has got it. You're overcooking it. As you train, you should gradually find that you can climb the same hill in bigger gears (lower tooth count cogs). If you start using smaller gears, you're overcooking it. To train at high HRs, you need a lot of base training in support. You can train at high HRs if you also have 2-3 rides at lower HRs per high HR ride. Otherwise you're tearing yourself down rather than building up. Don't quote me on that ratio, but that's the general idea. Running does always produce a higher HR than cycling for the same apparent effort.
The idea of lactate in your heart killing you has been discredited. So it's not dangerous, it just doesn't work as a training scheme. Although . . . If you only ride once or twice a week, you will derive more benefit by doing that ride or rides hard than easy. It's just frequent hard rides that are not a good idea.
Carbonfiberboy is offline
Reply
Old 03-31-08 | 03:18 PM
catherine96821's Avatar
Look 555 fledgling
Bikes: Vitus road bike, I bought used, graduated to a LOOK 555
this is what I picked from your post to hone in on.
That's not normal. Is it pychological, anxiety..etc? Almost sounds like you are having some acid base imbalance from hyperventilation. And sometimes people get pleuricy type pain between the ribs from strenuous aerobic workouts too, that will make you breathe shallow. It's kind of a sharp "knife" like pain in your pleural region and makes respirations *guarded*.
just some ideas.
Ask your doctor about
The faster breathing rate changes your acid-base balance and this takes a little longer to correct.
You might be compensating with a slower rep rate because you blew off too much CO2 and got a bit too alkaline and your body is compensating by trying to retain more Co2 to replenish your carbonic acid to equilibriate your serum pH. But...I could be wrong, wrong, wrong. I would bring this slow respiration bit up to a good sports medicine doc.
If you hyperventilate intentionally (blowing off too much CO2) you'll probably notice the same symptoms?
catherine96821 is offline
Reply
Old 03-31-08 | 07:07 PM
That doesn't sound good. It isn't painful when I breathe, but I feel like my lungs aren't expanding as far as they should. I haven't felt it after short sprint intervals, but if I exercise for like an hour or so and my heart goes over 190 at some point, I feel it for the rest of the day.
Reply
Old 03-31-08 | 10:18 PM
JPradun's Avatar
Pokes On Spokes
Bikes: Pedal Force ZX3
Some of the advice here is great.
Most of it makes me cringe.
JPradun is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
