Minimum safe tire pressure - newbie question
Hi all,
I tried searching for the answer to this question elsewhere on these forums... couldn't find exactly what I was looking for...
I haven't ridden in 30 years... just got a Trek 7.5 FX... awesome bike... however the only thing I found disconcerting about my first ride was how jarring it was, as I hit every bump or rut on the local paved bike path. When my LBS set the bike up, the tech mentioned he pumped the tires to 105 PSI. Since riding the bike 4 more times, I've discoverd that I get a very comfortable ride with the tires at 75 PSI.
So the question is, how low can I go on a 110 max psi tire, inflated to only 75 lbs, before problems arise? Most everything I've read on these forums suggest reducing the tire pressure by only 5 or 10 lbs, yet the "Ideal Inflation" table found at: https://www.precisiontandems.com/phot...tirechartx.jpg says I should be riding at 72-75 lbs... pretty much right where I like it now.
Here's all the data:
Bike: Trek 7.5 FX
Tires: 700 x 32c Bontrager Race Lite Hardcase (actual width 30.5mm)
Max pressure: 110 lbs
Wheels: Bontrager SSR (don't know anything about these as I can't find them on the Bontrager website)
My weight + bike: 230 lbs
My comfortable speed right now: 13-18 MPH
Thanks in advance for your comments!
Barry
Bike: Trek 7.5 FX
Barry
POWERCRANK addict
Just keep the tyres inflated enough that you don't get pinch flats and you'll be fine.
shameless POWERCRANK plug
Recommended reading for all cyclists - Cyclecraft - Effective Cycling
Condor Cycles - quite possibly the best bike shop in London
Don't run red lights, wear a helmet, use hand signals, get some cycle lights(front and rear) and, FFS, don't run red lights!
don't try this at home.
Quoted: 973 Post(s)
Liked 511 Times
That must have been a rough ride.
See Sheldon Brown's tire pressure page.
From psimet2001's tire pressure formulas: (see this thread - lots of good information)
Tire Width=32: Pressure(psi) = 0.17 * Rider Weight in lbs + 41.67
So a 210 lb rider would calculate to 77 psi for the rear tire, less 10% for the front =70 psi.
Your tires are slightly narrower, so you might want a bit more pressure in the back. Pinch flats happen when the tire bottoms out against the rim when you hit something big, like a pothole. So pressures aren't as critical if you are a careful rider.
I calculate 107 psi for my 23 tires, just about right, I use 105-110 in the back, 95-100 in the front.
Quoted: 1572 Post(s)
Liked 643 Times
The issue is "pinch flats". If you don't have enough air pressure in your tires, when you hit a bump the tire will compress and the rim will make two little parallel slits in your inner tube.
Bike shops will generally inflate tires a bit above the optimum level because it will make the bike ride a little faster (customers' like that) and not pinch flat (customers' don't like flat tires). Bike tires also lose air pressure over time so, by over inflating the tires a bit, the bike shop is buying themselves a little time before the dreaded pinch flat can occur.
If you are happy and not pinch flatting at 75psi, that's a good air pressure for you. Just keep in mind that you might not have a lot of safety cushion so you need to check your air pressure frequently.
Soma Lover
Bikes: one bike for every day of the week
I generally run my 32's (which measure 29mm on Mavic Open Pros) at 75-80 psi rear and 70-75 psi front. I weight 155 lbs., the bike is 25 lbs., and I generally carry 15-20 lbs. of gear on the commute. I ride gravel roads, ride off curbs, blow off potholes, and hop up curbs all the time complete with a rack and panniers and have yet to pinch flat. I think you're fine if you're careful but I'd go up 5-10 lbs. if you're going to ride aggressively.
Time for a change.
Liked 5 Times
I run 120 to 140 psi in my 23's as the normal pressure- but that is put in with a track pump . Out on a ride and punctures occur. I pump as hard as I can with the pump and that is it. On checking back home and that pressure was around 80psi. Mountain bike pumps on road tyres don't get you very high- but then I am only 150lbs and ride carefully avoiding lumps in the road.
Now got a Topeak road morph pump and can get back to 120 psi and then I get bored with pumping.
Spike Milligan
Spike Milligan
Humvee of bikes =Worksman
Quoted: 10 Post(s)
Liked 6 Times
Hi all,
Bike: Trek 7.5 FX
Barry
Bike: Trek 7.5 FX
Barry
to watch for tube pinching.
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Originally Posted by krazygluon
Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
n00b
Bikes: nice Raleigh roadbike and an S&M BMX
That bike also comes with higher pressure road type tires. Maybe if you want such a low tire pressure you should try out some larger tires or even hybrid tires.
I weigh a bit more than you do (240 without the bike), and I run 700x35 Paselas on my Atlantis at 75 psi with no problems ever. I'm sure I could go at least 5 psi lower without pinch flatting on decent pavement, but there's not a lot of that around here...
I think your best move would be to go up a size or two. I rode for years on 25s and 28s before switching to 32s and 35s (Grant Petersen recommended it for riders my size when I bought the Atlantis), and the larger tires made a big difference. Paselas (which I love, and have put on all three of my road bikes) run very true to the labeled sizes--my 35s measure 34.5--and come up to 700x37. If you can't find them anywhere else, look here: https://www.rivbike.com/products/list...product=10-071
All,
I sincerely appreciate all the awesome comments. Now I feel much better about what I'm riding on, and all the rest of your advice is not lost on me. Now I'm excited about experimenting with different pressures- especially the advice to keep the rear a little higher than the front.
Again, thanks to all for your time!
Barry
Barry
Conquer Cancer rider
Bikes: Fun bike, city bike, Bike Friday, Brompton (also fun bikes)
Quoted: 18 Post(s)
Mind you, once you get used to the jolts, you will get a much faster ride when you pump the tires up to 100. And it will be much, much easier to ride.
Zero gallons to the mile
