Bulbs for Generator Lights
Old 03-19-08, 04:37 PM
Does anybody know where I can find 6V/2A bulbs for my old generator lights?
sffuji is offline
Old 03-20-08, 03:53 PM
Scott
n4zou's Avatar
Bikes: Too Many
Are you sure it uses 2 amp bulbs? Most dynamo or generator lights use a 6V 2.4 watt bulb with a .6 watt taillight or a 6 volt 3 watt bulb without a taillight connected.
A well stocked bike shop will have them or visit a few large online bike shops that stock them.
n4zou is offline
Old 03-20-08, 03:58 PM
genec
genec's Avatar
Quoted: 13658 Post(s)
Liked 4,532 Times in 3,158 Posts
Anybody hook up an LED light to a generator?
genec is offline
Old 03-20-08, 04:33 PM
**** that
mattm's Avatar
Quoted: 1099 Post(s)
Liked 104 Times in 30 Posts
lumotec makes LEDs that hook up to dynohubs.
also you can get replacement bulbs from sheldon's shop, harris cyclery (link)
cat 1.
my race videos
mattm is offline
Old 03-20-08, 04:46 PM
Mr York's Avatar
Not yet, but you would need a full wave rectifier and a capacitor to turn the ac output of the generator to steady DC that the LED could use. You would also need a current limiting resistor for the LED. Depending on the voltage output, you may also need a voltage regulator.
This circuit looks interesting, but may be too complicated for some to tackle themselves:
https://www.elecfree.com/electronic/r...ynamo-bicycle/
But it handles recharging NiMH batteries and the LED light and looks like it would be just perfect.
Here is another design:
https://www.gobike.org/feat_lights.php
Mr York is offline
Old 03-21-08, 08:35 AM
Scott
n4zou's Avatar
Bikes: Too Many
Dynamo-Powered LED Light Circuits for Bicycles.
https://www.pilom.com/BicycleElectron...moCircuits.htm
My circuit and the description. https://www.bikeforums.net/electronics-lighting-gadgets/390107-my-new-led-headlight-usb-dynamo-circuit.html
n4zou is offline
Old 03-21-08, 04:21 PM
I assume you mean the common 6V 3W halogens that are common for generator systems that are not powering a taillight. An expensive solution would be to order direct from the UK at reflectalite.
Depending on whether your generator's output is DC or not, you can go with various LED conversions as well. I'm not that familiar with generator systems. Do they tend to be DC, or AC? Also, are they constant voltage, or constant current (what happens when you go too fast?)
FWIW, I have two 6V 2.4W halogen bulbs I'd gladly sell for $5 a piece, $8 for both.
Ngchen is offline
Old 03-22-08, 07:26 AM
Scott
n4zou's Avatar
Bikes: Too Many
The German government in the 1950's set the requirement that all bicycle dynamo lighting systems be 6-volts AC 3-watts. Everyone followed this standard with with few exceptions. It's still with us today. A bicycle dynamo is an exceptionally simple device consisting of a rotating magnet and 4 or 8 poles made of layers of thin steel with a coil of fine gage magnet wire. Hub dynamos typically have 28 coils and 28 magnets. There are no brushes so there extremely reliable. All tire driven dynamos are sealed and not serviceable. There's nothing in them that you can repair anyway considering how little they cost to replace. Dynamos appear to be constant current devices in that current is limited by design to about 500mA. Voltage varies with speed. Quality dynamo systems include Zener diodes to prevent high voltage when the bicycle is traveling at high speeds from burning out the filament in old style bulbs. Modern LED lights do not need high voltage protection. New high power LED's from Cree and SSC can sink 1,000mA or about twice the maximum current a standard dynamo can produce. Until about a year ago dynamo lighting systems utilizing standard or halogen bulbs were considered inferior to battery powered systems. This is no longer true. A Cree or SSC LED used with good optics can produce as much or more light than battery powered systems costing hundreds of dollars.
n4zou is offline
Old 03-23-08, 03:56 AM
Zoom zoom zoom zoom bonk
znomit's Avatar
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times in 366 Posts
Yep.
See my dyno link in sig for state of the art in batteryless bike lighting.
Easy to build a good system.
...mounting lights is the hard part
znomit is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
