Bmx brake on drop bars...
Old 03-21-08, 07:23 AM
ALL PARTY
ryansexton's Avatar
Bikes: Douglas Touring Cross Wise, Urbanite Fixed Gear
Post pictures if you did it. I ride mostly on the tops/bull horn position, and when I am in the drops it would be easier to move to the tops to brake than to move from the tops to another position to brake. My hoods and tape are all ripped up from falling, so I am thinking it is time to switch to a top brake.
ryansexton is offline
Old 03-21-08, 08:30 AM
it might have a different clamp diameter. a cx brake would probably work better.
conor is offline
Old 03-21-08, 08:43 AM
partly metal, partly real
sp00ki's Avatar
Bikes: Hummer H2
you should really consider seeing a neurologist before you go on any more rides.
sp00ki is offline
Old 03-21-08, 08:45 AM
ALL PARTY
ryansexton's Avatar
I am inclined to believe you:
A) Ride slow always
B) Don't ride in the snow
C) Don't ride at all
D) Stick to riding fixed on trainer/rollers and are actually the guy that made Rash SF.
Old 03-21-08, 08:48 AM
sp00ki's Avatar
Bikes: Hummer H2
E) none of the above.
Actually, i don't ride in the snow, but as we saw in your "this is how i fell ten times this week" thread snow isn't your issue.
seriously, you fall a lot. judging by your typical posts, this is likely indicative of a problem you should really work out before things get worse.
sp00ki is offline
Old 03-21-08, 08:50 AM
F) don't suck at riding a bike.
veeco23 is offline
Old 03-21-08, 08:51 AM
sp00ki's Avatar
Bikes: Hummer H2
with a little supervised therapy and our prayers, this is something he might one day achieve.
sp00ki is offline
Old 03-21-08, 08:52 AM
ALL PARTY
ryansexton's Avatar
Considering I fell once or twice in the last 3 years of riding at least two hours a week in favourable conditions, and about a dozen times in the snow, I think it has everything to do with ice.
Old 03-21-08, 08:55 AM
you ride 2 hrs a week?
veeco23 is offline
Old 03-21-08, 08:56 AM
womens feet rule
how about i pay yall a visit to your homes and whoop your sorry ass
vocaltest is offline
Old 03-21-08, 08:58 AM
ALL PARTY
ryansexton's Avatar
Anywhere from 2-20. On weeks where I am swamped with work I just ride my bike to school and a few quick rides, and when it is warm and I have nothing to do, I ride about 4 hours a day.
Old 03-21-08, 10:19 AM
live.fast.ride.faster
Velocità's Avatar
as conor said you might run into problems with diameter. i had to file the clamp innards down in order for it to fit, but i was also able to get it on the bulge which is a plus.
Velocità is offline
Old 03-21-08, 01:07 PM
jerk store
mathletics's Avatar
Bikes: '80s Chimo Garbage fixed 36/14, Centurion fixed 42/17
Do you have a reason to get a BMX lever versus an inline/cx/interrupter lever? The latter was designed to fit on drop bars (they usually have a 24mm ID for the clamp). You can even double up and control your front brake from both sides of the stem, like this:
mathletics is offline
Old 03-21-08, 01:29 PM
shiz bichiz
I have an old Odyssey lever on my flip and chops. I'll try to get a pic this evening. It was on Soma urban pursuit bullhorns before and the clamp barely fit. When I chopped the 3TTT bar I had to go to a longer bolt for the clamp, but it worked out fine.
andrewro is offline
Old 03-21-08, 02:04 PM
sp00ki's Avatar
Bikes: Hummer H2
can you explain this? i'm not sure i get how the drive-side lever works...
sp00ki is offline
Old 03-21-08, 02:15 PM
jerk store
mathletics's Avatar
If you get how the non-drive-side works, you get them both. Both levers push housing instead of pulling cable, as they are inline levers. However, instead of pushing the cable towards the brake caliper, they both push the center cable towards the opposite lever, flexing the cable and clamping the brake.
Old 03-21-08, 02:38 PM
Build your own's Avatar
Bikes: Pake,Shogun,Nishiki,Motobecane
Why????
Build your own is offline
Old 03-21-08, 02:49 PM
sp00ki's Avatar
Bikes: Hummer H2
ah, ok. not intuitive, but when i looked at mine it made sense.
sp00ki is offline
Old 03-21-08, 02:54 PM
barba's Avatar
Originally Posted by Build your own
Why????
So you can brake with either hand.
barba is offline
Old 03-21-08, 02:56 PM
jerk store
mathletics's Avatar
Why????
When braking on long descents you can switch hands; or, I am right handed, so I carry stuff with my right arm and need to brake with my left, but when riding normally I need my left hand to signal, so I brake with my right.
Old 03-21-08, 04:29 PM
scrub is offline
Old 03-21-08, 04:42 PM
POWERCRANK addict
markhr's Avatar
very popular in London
shameless POWERCRANK plug
Recommended reading for all cyclists - Cyclecraft - Effective Cycling
Condor Cycles - quite possibly the best bike shop in London
Don't run red lights, wear a helmet, use hand signals, get some cycle lights(front and rear) and, FFS, don't run red lights!
markhr is offline
Old 03-21-08, 04:44 PM
POWERCRANK addict
markhr's Avatar
That's one of the best setups I've seen.
markhr is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
