Alt Bike Culture Chopped, dropped, stretched, lifted, and otherwise cut up and put back together. The art and science of choppers, cruisers, lowriders and the vast world of mutant bicycles.
Bronco Bike
Old 03-27-08 | 06:28 PM
los buenos's Avatar
Bikes: a crappy doubletallbike, an atomic zombie spincycle, a homemade swingbike, a chopper, and many unfinished projects
Bronco Bike
i know spring will be here soon and i will probably have enough recourses to build it but out of the fear that i may forget too, i make this post to make sure the dream never dies! i am planning on building a bronco bike(front and back wheels) and want to know if there is some reason why i shouldn't/can't or even if i could see some pics of some working ones? (you know what a bronco wheel is right? a wheel where the axle is off center causeing bouncing when it rolls, everyone knows that, silly!)
los buenos is offline
Reply
Old 03-27-08 | 08:01 PM
squintal's Avatar
Bikes: 1984 Medici Pro strada running fixed, late 90's Cannondale road bike, 1999 Gary Fischer Paragon mountain bike
check this one out (the second picture down):
https://www.fixedgeargallery.com/2006....J.Enright.htm
I have no idea how a regular bike would work. I imagine the front would be pretty hard to control with an off-center wheel - but I guess that's half the fun.
fixed-gear, or disk brakes would be a must.
good luck, and keep us posted!
squintal is offline
Reply
Old 03-27-08 | 09:58 PM
lz4005's Avatar
coasterbrakelockup
Bikes: surly steamroller w/coaster brake, electra single speed cruiser, specialized rockhopper commuter, no-name single speed folder, 700c ultimate wheel, 24" unicycle, specialized bmx lsd, single seat single speed huffy tandem, pink upsidedown parade bike
If you're talking about a bronco bike with a chain and crank, as opposed to a bounce powered bike like an Ingo, any kind of hub brake would work. Coaster, drum or disc.
The only thing to remember about using a regular frame is that you'll have to use smaller wheels than it came with. A 20" wheel with the hub offcenter by 4" will need frame clearance like a 24" wheel.
lz4005 is offline
Reply
Old 03-27-08 | 10:44 PM
Actually, that example would need 28" clearance.
Sorry to be picky
Hillsy is offline
Reply
Old 03-28-08 | 04:48 AM
From bike kill in brooklyn, maker unknown to me
https://flickr.com/photos/redridingho...ions/60293334/
travesties is offline
Reply
Old 03-28-08 | 09:01 AM
lz4005's Avatar
coasterbrakelockup
I hate math.
You're right. So...um...lots of extra clearance.
lz4005 is offline
Reply
Old 03-28-08 | 10:00 AM
cman's Avatar
Here is one from a friend. w/ video
https://vanscyoc.net/blog/archives/309-Bronco-Bike.html
cman is offline
Reply
Old 03-28-08 | 05:38 PM
el padre
Bikes: Rans Stratus, ICE TRike, other assorted
I like your technology of the bigger rim welded with "spikes"...that eliminates the need to have a lot of different spokes.
great job from my point of view...looks fun to ride too.
Floyd is offline
Reply
Old 03-28-08 | 08:18 PM
los buenos's Avatar
i just finished makeing similar rims, i had to lengthen the rear triangle on a fram so the rear wheel will fit, so i cut the arms off some forks and attached them, the upside to this is i can put them downward makeing the pedals less probable to scrape, ill get pix in the morning
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
