O Ring for Campagnolo Record Brake Adjuster
Bikes: Tierra, Nobilette,Merz,Jack Taylor, Lippy
Looking for the correct size 0 ring to replace one missing on a 80's vintage Campagnolo Super Record brake adjuster. Thanks for your response
Unique Vintage Steel
Dale Brown over on the Classic Rendevous list just answered this, let me see if I still have that email...
Check Lowes or Home Depot:
Quote from Dale:
# 31 O-Ring
9/16" x 5/15 x 1/8
Stock #35745B
Danco Co., Concordville, PA
(made in Taiwan!)
Also found this bit of information from another list member:
Dale mentioned #31 o-rings, but I really prefer #48, meself.You can find them in the plumbing section. #48 is awfully close to the original rings, and is within about 0.5 mm in all dimensions, once mounted. Be careful, though, as there may be more than one size that is marked #48. You want the one that is nominally 3/8" x 5/8" x 1/8" although they are actually a bit fatter than that (which is good).
Quote from Dale:
# 31 O-Ring
9/16" x 5/15 x 1/8
Stock #35745B
(made in Taiwan!)
Old Junior Member
Bikes: 1974 Italian frame with Campy Nuovo Record Components, 2016 single speed
Epicus07
12
09-01-15 07:55 PM
Danbianchi881
1
06-23-15 06:39 PM
silvercreek
Classic & Vintage
5
12-23-11 03:15 PM
