Look Keo
Mitcholo
Bikes: 2010 Mitcholo w/ Sram Force/Red
Look Keo
I heard that some pro riders have managed to get a strap onto their Look Keo pedals. Does anyone have a good picture of this mod, or know how to do it?
Bikes: Pedal Force QS3
Took this myself of a Chinese nat'l team bike.
15% Hammer Nutrition Discount Code
Mitcholo
Thanks, but do you have any idea how the mod plate is attached?
Bikes: surly steamroller - towniefied.
looks like something that was milled out of a good chunk of aluminum. maybe a second smaller plate binds the two from the other side.
I remember seeing an SPD-SL (not SPD-R) pedal that had a hold drilled through part of the pedal so that a toe clip could be screwed into it. You might be able to do something similar to a Keo, but I'd make sure you aren't drilling through anything important first.
Bikes: Scapin EOS7 sloping, 10v Record, Ksyriums
N+1
Bikes: A few
Liked 5 Times
https://www.badbean.com/cyclingstuff/spd_straps.htm
Here is a method for adding a single strap to a Shimano SPD-SL pedal. The idea would be the same and it should be able to be changed to work with a set of Keos.
Built only for Kilo.
https://www.cyclingnews.com/tech.php?...ursuit15-pedal
Very good idea!
@ed073: Thx for the information!
Very good idea!
Bikes: Bianchi Pista, Bianchi Vigorelli
I just thought I would post this up incase it helps anybody. I was interested in adding straps to my Track Pedals, so that I could use one shoe/cleat combo for all my bikes. I was using the old style look cleats (don't laugh) and this was my economical solution. The pedals I used are quite cheap, and performance also offers a similar pedal that is keo compatible, but not that cheap...
The Forte pedals have a small hole created by the pedal body and the retention spring. You can thread a small zip-tie through the hole and make a loop. Cut the excess zip-tie. Now you can thread the strap through the two looped zip-ties when you need them, and leave them off when you don't. the zip-ties only support the straps when they are not on your foot. Once the straps are tightened, the body of the pedal takes all the weight. You may not see through the pictures but the body of the pedal has a perfect groove that the strap positions in when loaded.
It is a very simple and effective system....
These are cheap and work with old style "look" Cleats
https://www.performancebike.com/shop/...slisearch=true
These cost a little more and work with "Look KEO" cleats (good pic. of the hole the zip-tie goes through)
