Do Certain shoes matter.
Bikes: Specialized Rockhopper Comp. and a Giant Sedona. Also a stationary bike.
I have been continplating on getting a pair of Mountain bike shoes. Do they really matter. or does any type of cycling shoe really matter. Now, take into consideration I am not on clip in pedals just yet. I thought I might wait for awhile before I go down that route.
Do some of these specialized shoes make any difference at all.
Out fishing with Annie on his lap, a cigar in one hand and a ginger ale in the other, watching the sunset.
Bikes: Techna Wheelchair and a Sun EZ 3 Recumbent Trike
Quoted: 9 Post(s)
Liked 22 Times
Yes, they do! If you want a walkable shoe that you can use with Clipps and straps, but can use with clipless later, get the Specialized Tahoe. It's a comfortable touring/Mountain Bike show and it looks like a normal shoe.
. “He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.”- Fredrick Nietzsche
"We can judge the heart of a man by his treatment of animals." - Immanuel Kant
Okay but, and forgive my ignorance in all of this. If I don't plan on getting straps #1 does it warrant getting a MTB shoe for any reason. Or should I just stick with my Cross Training shoes. and spend the money elsewhere on other things that may come up with my bike.
Quoted: 9 Post(s)
Liked 22 Times
Well, the Tahoes will run about the same price as a good set of Crosstrainers, and offer a much stiffer sole. In addition, if you decide to go to the cleatlocked "Clipless" style pedal for greater efficiency in power transfer,you'll be ahead of the game and they'll offer a wide range of compatibility to the cleat systems.
POWERCRANK addict
Time, every time!
https://www.timesport.fr/us/home.htm
https://www.mtbr.com/reviews/manufacturers/3421/
Sidi SRS only!
https://www.sidisport.com/
https://www.mtbr.com/reviews/manufacturers/3490/
shameless POWERCRANK plug
Recommended reading for all cyclists - Cyclecraft - Effective Cycling
Condor Cycles - quite possibly the best bike shop in London
Don't run red lights, wear a helmet, use hand signals, get some cycle lights(front and rear) and, FFS, don't run red lights!
Gorntastic!
shoes and clipless pedals are one of the best upgrades for your bike
I second the recommendation for Sidi shoes. They are a bit on the expensive side but very well constructed. My Sidi Dominators have lasted 12 yrs.
Specialized has some less expensive offerings that are nice too.
JRA.
Bikes: '07 IRO Mark V, '01 Cannondale Jekyll 3000, '07 Rivendell Atlantis
Ditto on the Sidis. I have a pair that I've been using for all my riding for about 3 years now they're holding up great.
2009 Bike Friday Season Tikit (commuting folder)
2007 Rivendell Atlantis (touring, general riding, errand runner, stuff hauler)
2007 IRO Mark V (SS)
2006 Rockhopper Comp Disc (Icebike)
Bikes: 1996 Specialized Ground Control
Not to hijack this thread, but, for those of us who have wide feet (10EEE), is there a shoe out there that will fit? I've had bike shoes before for clips, but they are really too narrow, even in a size 12. At this point in my life, I refuse to pay more than $10 for a pair of shoes that don't fit. Anyone?
Jim
Jim
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
I'm reading something else in the original post. I'm taking it that he poster is asking if he should go with a mtb shoe eventhough he isn't riding clipless pedals. Maybe I'm a dufus, am I wrong?
If you aren't using clipless pedals, don't go with a mtn bike shoe if you are using to straps (toe clips). The sole is aggressive which means you will not be able to slide your foot out of the straps in an emergency.
If you use plain platform pedals, then yes a mtb shoe will make a difference. It is stiff at the sole and makes for a better cycling. A tennis shoe will flex all over the pedal. MTB shoes are a bit stuffer and less flexible.
If you use clipess pedals ( clip in cleat type) then yes it is a good idea to go with a mtn shoe. Or a road shoe system depending on which you prefer.
I ride road bikes but use a mountain shoe as I find it more comfortable. When you get ready to go clipless, chose what works for you. Some roadies insist road shoes work better. I find mountain shoes work for me. I like the better traction, especially when riding a tandem supporting the weight of two riders on my feet. Just had a friend do the splits on Saturday when he unclipped in a near emergency situation. He did get his foot down but the slick sole sent him sailing.
Quoted: 9 Post(s)
Liked 22 Times
As I was able to parse, he wants to ride platforms and no straps. That was my reason for suggesting the Tahoe
That way, if he DOES convert to locking cleat pedals, he's ahead of the game He could look at Schimano's campus pedals, for example
Nashbar version here
+1 on the Tahoe shoes. I got them and a set of commuter pedals with SPD clip on one side and flats on the other. I use the clip for almost all my rides, but when I want to run to the end of the block for a coffee I keep my work shoes on.
I am using the Shimano 324 pedals.
POWERCRANK addict
Jim
Jim
They're extra wide and even fit my aboriginal feet (the shoes are available up to an ~EU52 EE-EEE) - by aboriginal feet, think of short, widely spaced, inflexible toes on a wedge shaped foot.
Bikes: Surley Crosscheck, 1988 Rockhopper Commuter
I was using regular "sneakers" before going clipless with the taho shoes mentioned above. One problem the sneakers had was that they were being cut into by the pedal. i was using very loose toe straps at the time and the shoes would rest in the same place causing the same place to get worn. I would figure from my experience unless you had a fairly smooth pedal, you will rip up a soft sneaker sole. That is one of the reason why I went clipless.
Eric
Eric
Thanks for the response guys I think I will eventually go clipless. I just have to now save up a little bit of money for that endevor. LOL.
I see sales every once in awhile on some of the sites like Nashbar. Wellgo SPD's for $29. Yeah everybody will say they are cheap but I bought a pair about 8 years ago, slapped them on my tandem. They are still there and going strong. I keep thinking I will have to replace them soon. They have outlasted several others I've had, more expensive models.
You can find really inexpensive shoes on Performance or equal. Any clipless system is an upgrade in my opinion.
Quoted: 766 Post(s)
Liked 1,739 Times
I was using regular shoes for about 3 months and I noticed an immediate improvement when I moved to clipless, but I think a lot had to do with the firm sole on the shoe and the lack of flex on the foot.
Guest
Posts: n/a
Quoted: Post(s)
Eric
Eric
fishologist
Bikes: Diamondback MTB; Leader 736R
Also look at pricepoint...sette shoes fit a wide foot and you can use them with or without clipless. I found them comfy
We cannot solve problems with the same level of consciousness that created them. A.E.
1990 Diamond Back MTB
2007 Leader 736R
www.cohocyclist.blogspot.com
https://www.loopd.com/members/cohocyclist/Default.aspx
2007 Leader 736R
Guest
Posts: n/a
Quoted: Post(s)
Thanks for the tip. At the risk of becoming the Imelda Marcos of cycling, I'm probably going to order a pair of the Sette Rivals. I like my MTB shoes, both pairs, but they aren't ideal for walking, and I tend to do a fair amount of walking on tour.
Guest
Posts: n/a
Quoted: Post(s)
If you use plain platform pedals, then yes a mtb shoe will make a difference. It is stiff at the sole and makes for a better cycling. A tennis shoe will flex all over the pedal. MTB shoes are a bit stiffer and less flexible.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
I totally agree clipless is a huge benefit. I rode with straps and toe clip for about a year when i started cycling and it felt fine so I was dubious about going clipless last summer. I took the plunge and it was the single purchase that made the biggest improvement so far, even more than buying my first cycling shorts. It allowed me to pedal in a circle.
Thanks for the info, folks. I have avoided riding with bike shoes for about 20 years due to the bad experiences I had with fit and all.
Jim
Jim
Well, I am certainly glad I have gotten this info because I will try my best to go clipless now.
Guest
Posts: n/a
Quoted: Post(s)
Only if you feel comfortable doing so. Unfortunately hanging around on Bike Forums draws you bike consumerism at full throttle. Don't get sucked into the feeling you NEED to ride clipless, or that you need to ride clipless right away.
