Feeling deflated - pumps & cleaning
On Sunday I gave my bike a thorough clean:
I must confess I was a bit worried that the proper bike cleaner I'd bought warned that it shouldn't be left on the bike for more than 30 seconds before being hosed off - I think I'll try car shampoo next time - any other suggestions?
For the first time since I bought the bike I decided to top the tire pressure up, I was pretty sure they were well above the minimum but I thought I'd try running them a little harder for the road. So for the first time I tried out the mini-pump I bought with the bike. To say it was useless would be a gross understatement. I'm convinced it let more air out than in, and I've got no confidence that in the event of a flat I could get the tire pressure up to a rideable state. In the end I borrowed my neighbours floor-pump and guage but I feel I need to look at another means of inflation for emergencies.
Any recommendations for a mini-pump that might just get a MTB semi-slick up to a reasonable pressure(from memory (the boss might get suspicious if I pop over and check the bike
) the min pressure is 35 max is 65 psi.)?I accept that for full inflation I'm going to have to buy (or borrow) a floor pump but a pump that can get to a pressure that's rideable at a reasonable speed and is small enough to chuck in a small pannier or preferably afix to the frame is probably a wise move.
p.s. apologies for mis-spelling tyre
Richard
) the min pressure is 35 max is 65 psi.)?I accept that for full inflation I'm going to have to buy (or borrow) a floor pump but a pump that can get to a pressure that's rideable at a reasonable speed and is small enough to chuck in a small pannier or preferably afix to the frame is probably a wise move.p.s. apologies for mis-spelling tyre
Richard
Currently riding an MTB with a split personality - commuting, touring, riding for the sake of riding, on or off road :)
human
Bikes: 2005 Litespeed Teramo, 2000 Marinoni Leggero, 2001 Kona Major Jake (with Campy Centaur), 1997 Specialized S-Works M2, 1992 Specialized Rockhopper
I've had a lot of success with the Crank Brothers Power Punmp. It's an extra-mini-mini pump that fits comfortably in a jersey pocket. It also has a high pressure/high volume switch, so I can pump at high volume until the pumping gets hard and switch over to high pressure. I find that 110 strokes gets me up to about 80 lbs on my road bike.
when walking, just walk. when sitting, just sit. when riding, just ride. above all, don't wobble.
The Irregular Cycling Club of Montreal
Cycling irregularly since 2002
Richard,
I have a Topeak Road Morph that is outstanding. It is a midsize pump, shorter than full-size frame pump, longer than a mini. The following features make it very easy to use: handle folds to make a T, fold down foot peg, hose, guage. I can get my 700x25 tires up to 110 psi in about 90 strokes and 120 pounds in about 100-110 strokes without much more difficulty than a floor pump. The built in guage is very handy. The pump comes with a plastic mount that velcros to the top tube (or other tube).
Regards,
Raymond
Regards,
Raymond
If it ain't broke, mess with it anyway!
feros ferio
valves
Are you using Presta valves? If not, strongly consider changing; you will need inner tubes and two appropriately-sized washers. I keep a Cyclo double-action minipump on the mountain bike and full-size Zefal HP-X pumps on the road bikes.
Yes - I think it's just a cheap and nasty pump.
Richard
Richard
Love Me....Love My Bike!
Bikes: Bikes: Giant hybrid, Trek 4500, Cannondale R800 Some commuting 20mi/day, mostly fitness riding - 20-50 mile rides
I'd vote for Topeak
I'm with Rainman on this one. I've got the Topeak mountain morph, it's the same but without the gauge and thus a little cheaper, but works like a charm.
"...perhaps the world needs a little more Canada" - Jean Chretian, 2003.
HomeBrew Master!
Bikes: Aegis Aro Svelte, Surly LHT, Cannondal R3000 tandem, Santana Triplet.
I third RainmanP and aerobat concerning the Topeak Morph! I also have the road version and it is far and away better than the Trek mini double pump that I struggled with for years.
The Flying Scot
From: North Queensferry Scotland and London (and France)
Bikes: Custom (Colin Laing) 531c fast tourer/audax, 1964 Flying Scot Continental, 1995 Cinelli Supercorsa, Holdsworth Mistral single speed, Dahon Speed 6 (folder), Micmo Sirocco and a few more
Richard,
I've been using a Blackburn Airstick, which is an aluminium (aluminum for our USA friends) which gets my tyres up to about 90-95 psi.
I use it in emergencies and recently got the longer version just so that I stroke less (oo err missus!). It pumps on the in and out stroke.
It mounts to a holder attached to the bottle cage.
plus je vois les hommes, plus j'admire les chiens
1985 Sandy Gilchrist-Colin Laing built 531c Audax/fast tourer.
1964 Flying Scot Continental (531)
1995 Cinelli Supercorsa (Columbus SLX)
1980s Holdsworth Mistral fixed (531)
2005 Dahon Speed 6 (folder)
(YES I LIKE STEEL)
2008 Viking Saratoga tandem
2008 Micmo Sirocco Hybrid (aluminium!)
2012 BTwin Rockrider 8.1
(YES I LIKE STEEL)
I liked the look of the Morph but with my cabling running on the underside of the top tube mounting it would have been a pain. On the advice of the LBS chap I went for the Topeak mini-master blaster DX instead. A fair bit smaller so it will take a bit longer, but he said he'd got up to 100 psi without a problem and it mounts under my water bottle cage (spare cage bolts was a nice touch
). I'll let people know what it's like in an emergency...(well actually hopefuly I won't
Richard
).Richard
