rolf sestriere bearing noise
hi im new to the site have a set of rolf sestriere wheels .the rear wheel under load creeks. has anyone had this problem and can the hub be cleaned and greased to stop this or do the bearings need replacement thanks for any help
ken
ken
Quoted: 2026 Post(s)
Liked 1,096 Times
Are you sure the problem isn't spokes creaking against each other or in the nipples? Put a drop of oil at each spoke crossing (I assume the wheel isn't radial laced on both sides) and nipple entry and see if that helps. Also try cleaning the dropout faces and tightening the qr skewer a bit more. The creak may be there too.
Bearings normally don't creak when they are dry. They either squeal or make a grinding sound.
Bikes: Giant TCR Comps, Cdale R5000, Klein Q-Pro, Litespeed Siena, Piasano 105, Redline Conquest Pro, Voodoo Bizango, Fuji Aloha
Wheel flex, happens with low spoke count wheels. Nothing to worry about.
