What does M 10 mean when I am looking for the metric size of a washer?
If I want to specify a (Teflon!)washer that is OD 20mm X ID 10, 3 mm thinckness... how do I ask it? and what company is a good source?
I would try your local hardware store. The exact washer you want may be hard to find; however, there might be alternatives like stacking several washers to get the 3 mm and so on. M 10 generally refers to something being 10 mm in diameter; I don't know whether for a washer it refers to the OD, ID, or something else.
Bikes: TREK 1000c
If the object you are sizing goes INSIDE something else ... the size is OD (ie screw, pin, etc)
That way, a 10mm washer fits a 10mm screw. Obviously the 10mm ID washer size is reference only because the "real" ID is "toleranced" larger than the screw so that it will fit over the screw.
