Garmin GPSmap 60cx 60 series larger mount
Hi,
Just got a new road bike, a Kona Zing:
https://www.konaworld.com/08_bikes.htm
It has a WIDE bar, the kind that has "flattened out" part near the stem, i guess it's supposed to be more comfortable on those long rides. Anyways, my Garmin GPSmap 60Cx mount won't fit. Garmin offers a larger mount (listed as fitting 25-32mm bar). As my bar in now "flat'ish" will it fit?
Here is a link to the bar mount:
https://www.amazon.com/Garmin-Large-D.../dp/B00030F6OC
I know it's only $13, but I hate ordering sh*t with the hope it will fit; and it turns out to be a waste.
I searched the forum to no avial
Love the bike, only have had it a week with 100km ridden on it. Rode 50 km tonight in the dark and sub freezing temps, froze my toes!
tia
tia
It depends on the exact size and shape of the flat area of the bar. The Garmin clamp is basically a rigid, circular clamshell sort of thing, so there's not going to be a lot of tolerance to irregular shapes. But if the flat part is within the acceptable 25-32mm diameter (preferably closer to 25mm), you may be able to wrap enough filler material around it to get a secure fit.
You might take a look at one of those accessory bar extender products, like the Minoura Swing Grip, Performance ViewPoint OS Spacebar, and Topeak BarXtender. These generally have a flexible metal strap that you tighten around the handlebar, then a t-shaped piece extending out that you can attach your Garmin mount to. Many of these can also articulate in ways that allow them to be attached to the stem.
Don't know about the others but the Minoura Swing bar is junk. Had mine disintegrate on me while riding. Looked like metal fatigue where the bar was attached to the arm. I had both my 60csx and Edge mounted on it. The wider mount for a motorcycle bar works on my 31.7 diameter bars.
Another suggestion to the OP might be to take a look what companies like RAM are making for motorcycle GPS mounts to see if anything will work. I know they have various bar mounts that usually involve U-bolts. I have a RAM windshield mount for my 76CSx and it's built like a tank, but would probably look pretty ridiculous on a bike.
Liked 7 Times
I have a Nitto and I have a GPSMap 60csx and a photo.
https://www.flickr.com/photos/gadgeta...7602389546909/
