IRO hub need spare parts help
Old 04-21-08 | 10:01 AM
The cartridges bit the dust in my IRO hub. I tried removing the axle/cartridges. What am I doing wrong. I whacked out the axle...I'm going to replace the axle because it had been bent for sometime now.
Where besides IRO can I order all the parts. How do I install the axle/bearings? My understanding is I whack it with a socket that fits around the cartridge but slightly bigger.
I am going to need all the nuts washers/axle etc...is IRO the best place to get all the parts? Does IRO sell the SKF bearings...Whhaaaaaaaaaa!!! poor me. I want my fixed gear back.
SoreFeet is offline
Reply
Old 04-21-08 | 10:22 AM
baxtefer's Avatar
Cornucopia of Awesomeness
psssst..... DIY thread
https://www.bikeforums.net/singlespeed-fixed-gear/347132-how-replace-bearings-your-formula-hub.html
get a new axle from Tony at IRO. Last time I asked it was $20 for the whole axle+bearings+spacers+locknut kit. Harris Cyclery also stocks axles separately.
baxtefer is offline
Reply
Old 04-21-08 | 11:10 AM
jerrymcdougal's Avatar
Bikes: 86' Davidson Impulse, 83' Windsor Professional
Also, your LBS should be able to get you Phil Wood bearings that will fit perfectly for about $10 per hub. I think they are 6000 series bearings. Bam, you have a poor mans phil wood hub. Just my .02
jerrymcdougal is offline
Reply
Old 04-21-08 | 11:53 AM
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
