Question: Adjusting front derailleur for bashring...
Old 11-19-03 | 01:58 AM
bentrim
Guest
Posts: n/a
Before I get my handy-dandy screwdriver out and screw everything up (no pun intended), I have a question.
I have a bashring on my crank so I only have a middle and small ring. I want to prevent the front derailleur (Shimano Deore) from shifting up onto the bashring. Can I totally eliminate the highest front gear (i.e. the large chainring where the bashring is) by adjusting the limiter screw on the front derailleur alone, or do I have to take anything else into consideration?
It's a relatively new ride which I haven't ridden much and it surprised me recently when I accidentally shifted up -- rather than down -- and the chain tried to gear up on the bashring. I figured my LBS would have eliminated that position when they set the bike up.
Reply
Old 11-19-03 | 06:55 AM
skdsl's Avatar
7 inch Weagle
20 Anniversary
just wind in the upper limit screw. Make sure it doesn't lock the deraileur completely, you may have to allow a little 'overshift' to get it to move freely.
skdsl is offline
Reply
Old 11-19-03 | 08:02 AM
25 Anniversary
Bikes: Lots
You should also move the derailleur down on the seat tube. You only need a couple of mm clearance between the outside plate of the derailleur cage and the bash ring.
L8R
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, What a Ride!" - unknown
"Your Bike Sucks" - Sky Yaeger
a2psyklnut is offline
Reply
Old 11-19-03 | 01:07 PM
bentrim
Guest
Posts: n/a
Thanks a lot for the advice, guys. I'll give that a try.
I'll remember to adjust the vertical height of the derailleur too.
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
