Using modern crankest on old Schwinn?
Solo Rider, always DFL
Bikes: Cannondale T800, Schwinn Voyageur
I have a Schwinn Voyageur, which has served me well, but for real utility duty I'd like some lower gearing. The bike is (IIRC) a 1981, with a six speed uniglide cassette rear.
Performance is clearing out campagnolo cranks, and I realized that a Centaur compact would be cheaper than a regular cheapo nashbar compact crankset, and was trying to figure out whether it would work with the drivetrain that I have. I assume I would need a different bottom bracket, but other than that, are there any issues to worry about?
I don't know why it would require a new FD, but I am open to any thoughts/criticism/advice available.
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
If you install a Centaur-compatible bottom bracket, you should be good to go, unless your chain has elongated with use. If you are keeping the 6-speed cogset, you will want to stay with an "8-speed" chain.
