Bianchi Pista build up
Hi all, I'm pretty new to riding fixed gear, and was looking for some advice on building up my Bianchi Pista. Everything on it now is stock, and I want to know what things I should add first, second, third, and so on to make this bike really nice. As far as I can tell, I love the frame, very smooth, and durable. I just need to know where to start. Also, I would love it if some people with other fixies, particularly Pistas, could post pics of their rides for some other ideas.
Thanks...
Thanks...
Señor Member
Bikes: Surly Steamroller, Specialized Sirrus, KHS Solo SE
You can get pictures of everyone else's "fixies" in the sticky'd picture thread. But why would you look to change parts so quickly if everything is fine? Wait till you find a reason to replace something, I'd say.
71 Peugeot. fixed.
stay free.
Bikes: EAI Bare Knuckle, 1980's Ross Signature 292s 12 speed
stay free.
71 Peugeot. fixed.
seriously, i'd think unless you don't want track drops the deda pistas that come with the bike are plenty fine.
granted, bars were the first thing i switched on my 01, but that's because i wanted flats/risers.
Bikes: 2009 Surly Steamroller, 19?? Fuji ?, 19?? Univega Viva Sport, Marin/Xtracycle combo
is this another one of those goddamn day dreamer threads? jesus!
you don't need to replace a goddamn thing on your bike. when something breaks, replace it with an upgraded part, or one of a different design if you weren't happy with the original part. if it's a personal fitment issue, keep riding the bike to see how you'd prefer things to be, and upgrade as you body sees fit.
of course, the other answer here is that you need risers, yellow oury grips, a brooks saddle, a green 650c arrospok up front, a pink deep v in the back, blue tires, platform pedals, and a BMX stem. then you can BARSPINNZ!
EDIT: ok, i reread this and i don't like coming across as a dick, so if i did i apologize. but i still stand by my point about wearing out parts first vs. replacing right off the bat.
mauve avenger
i still thought it was pretty d*mn funny
son of a son of a sailor
If you plan to do skid-stops, replace the cog. Pistas are known to come with sh***y cogs that will slip out. It takes a lot of pressure to make it slip, but it's not impossible.
Bikes: '07 Pista, '09 Fantom Cross Uno, '8? Miyata, '67 Stingray, '0? Zoo mod trials, Tallbike, Chopper, '73 Schwinn Collegiate, '67 Triumph Chopper, '69 CB350, '58 BSA Spitfire, '73 CB450
Also the condenser, stator, rectifier and plug wires.
j/k.
The first thing I did was toss the ***-hatchet in favor of my well-worn brooks. I brought my pedals to the shop when I got it, so I never used the stock plastic ones. Eventually I pulled the track drops off since it was winter and I never used the lower position and traded for risers and bullhorns (depending on where I am going).
j/k.
stay free.
Villainous
Bikes: Trek 420, Cyclops
Brake
Brake lever
cable and housing betwen the two
Red blinky in back
White blinky in front.
Be a safety ranger!
Brake lever
Red blinky in back
Be a safety ranger!
a.k.a. QUADZILLA
Bikes: Super Pista, Basso, Big Dummy
I love pista hating. I had a bunch of money so I upgraded everything: Brooks team pro (best upgrade I made), 3 different sets of pedals (mks sylvan, mks custom nuevo (plus toshi double straps), time atac + sidi dominator 6 [second best upgrade unless I want to do trickeseses]), new threaded fork (from spicer), chris king grip-nut headset, two quill stems (jaguar and pearl), 2 sets of bars (nitto rb-21 & b-123aa), sugino 75 bb, cranks and chainring, 2 cogs (15t gold star & 17t superstar from eai), nitto jaguar "saddle pillar", phil wood hubs and deep v wheels and izumi super toughness chain. Most of it was just me wasting money, from a need/performance standpoint.
only upgrades that would make a big difference would be a decent wheelset. everything else is just for looks/comfort imo. cranks too i guess.
tarck bike.com exile
Bikes: bfssfg iro--black.
first thing's first: sugino 75s. then mks royal nuevos. then toshi doubles. then a aerospoke front. then a deep v laced to a phil in the back. then some pricey deda track drops.
then if you have any money left, buy a really expensive rope and hang yourself.
King of the Hipsters
Bikes: Realm Cycles Custom
I love the Pista.
If I had a custom frame made, I'd tell the maker to use my Pista frame as the model.
My headset failed on me fairly early on, but then I weigh 235 when riding all up.
King makes the lightest and best headset, but also the most expensive.
Cane Creek has a whole range of headsets, from inexpensive to very expensive, and they all do a good job.
Soon after my headset failed, I broke a spoke, which happens not too often, but it happens.
Wheels, tubes and tires represent the most meaningful upgrade, in my opinion, but it costs money.
Cane Creek's Volos Track wheel set costs about $550, a slug of money, but they significantly reduce the rotational inertia of the wheels, which makes for better acceleration, braking (not everybody skids), and climbing (unless the rider has an absolutely perfect spin, he or she must re-accelerate his wheels against gravity twice per rpm).
A Continental Four Season tire in front, Continental Gatorskin in back, and Salsa Superlite tubes, with the Cane Creek wheels, costs close to $650 but it makes for a very light, strong, grippy, flat-resistant and quick package.
A Stronglight 130 BCD crank from John Dace at Businesscycles for less than $125 provides the lightest crank available, with plenty of strength and precision.
Combine this with a Phil 108mm JIS bottom bracket for $109, and Phil cups for $35 and TWO bottom bracket tools for $28.
This gives access to the world of cheap, light and efficient 130 BCD chainrings.
I have 39t, 42t, 46t, 47t, 52t and 53t chainrings.
Use only EAI cogs.
Do not switch cog manufacturers because the slight diffences in threading will shorten the life of the rear hub.
I have 16t, 17t, 18t and 19t EAI cogs.
A 17t and 19t cog, with 39t, 42t, and 46/47t chainrings, provides a huge range of gear inches, and allows a lot of experimentation.
I have ridden 82 gear inches to 54 gear inches, and everything in between.
They all have merit depending on the situation.
I have found hard saddles more comfortable, in the long run, than soft saddles.
Selle San Marco makes a nice Ti Aero Aspide that weighs less than 200g and costs less than $125.
Jenson and Performance both list this saddle.
Not everyone likes it, but a lot of people do.
I like bullhorns and bar end brake levers.
They don't cost much.
I invested in a bunch of very cheap stems of various lengths and degrees of rise.
I went through seven or eight combinations before I found out that 90mm and 6 degrees of rise works for me on the street.
Then I bought a higher quality (and more expensive) stem of those dimensions.
I ride with Shimano 970 double-sided SPD pedals, but 540's do just as well for half the money.
These pedals make sure I can clip in effortlessly in a hurry, and in three years I have unclipped twice, both times just a little earlier than I planned.
I brake by back pedaling (I ride on expensive tires and I get a year out of them), and I stop quickly, and I have never unclipped while braking or at high spin rates.
Shimano's cheapest Mountain Bike shoe does a great job and I can walk in them very comfortably.
I sometimes forget I have them on my feet.
So, Cayman, upgrade as you can afford it.
I makes for a great hobby, and I enjoy the planning, saving, and anticipation almost as much as putting the upgraded part on the bike.
I've shared what I did with my Pista, and you will probably make different choices.
Have fun.
Use only EAI cogs.
Have fun.
or tarckeemoon, depending
Bikes: Davidson Impulse, Merckx Titanium AX, Bruce Gordon Rock & Road, Cross Check custom build, On-One Il Pomino, Shawver Cycles cross, Zion 737, Mercian Vincitore, Brompton S1L, Charge Juicer
Wheels are probably your best bet if you're happy with the fit.
