Bib-shorts vs. normal shorts
Bikes: EVO, FUJI Track, etc
Agreed, bibs are much more comfortable then shorts. They do make it a little more difficult to pee as you need to...umm pull the leg open which is not that bad with a little practice. Plus the bibs provent my big belly from hanging out.
Life is good
Bikes: 2018 Lynskey Helix Pro
I made the switch from shorts to bibs in June. I love 'em. I'll never go back.
There is no elastic or drawstring to cut into your midsection or restrict your breathing.
Love Me....Love My Bike!
Bikes: Bikes: Giant hybrid, Trek 4500, Cannondale R800 Some commuting 20mi/day, mostly fitness riding - 20-50 mile rides
I like my Campagnolo bibs, but to be honest, I havn't found that big a difference. I think I like them better because they're just a better quality (and more expensive!) overall than the other shorts I have.
"...perhaps the world needs a little more Canada" - Jean Chretian, 2003.
Well bibs hold the padding in place much better than normal shorts, and as that region tend to be an important one,this is a plus. Honestly though, if you've never ridden with bibs, don't make the switch unless you can buy a few pairs. I know when I got mine I never wanted to wear shorts again.
Uh oh, here comes the Underwear Nazi!
I've personally never worn bibs, but I think I'd like to try them out--seems like they would prevent the problem of shorts sliding up or down and requiring constant adjustment.
Guest
Posts: n/a
Don't forget that there is a hybrid between shorts and bibs: shorts with suspenders (braces). Greg LeMond recommends using suspenders with shorts in his book. That's what I did before I could afford bibs. I still use them with my old shorts. KMart has some simple, sort of industrial suspenders that work great. And here is the hybrid advantage for the guys: you can detach the clips from the front for a standing pit stop.
Rich
Rich
I still wear shorts, even though everyone I know wears bibs. The main reason I stay with the shorts is they make it easy to pee, and I go often. As far as the elastic around the tummy thing, I just roll down the shorts and wear them low. Bibs are also a lot more expensive, here anyhow. With Summer being +30ş/86F everyday I don't want anything adding unnecessary heat to my body.
CHEERS.
Mark
CHEERS.
Mark
I don't want to turn this into a "what is the best brand" argument, but I am thinking about getting bibs so I can be ready when I buy my new bike next May.
I am 6'3", 240lbs, and would like other "normal" sized guys to comment on the fit and feel of the various brands. This has probably been asked several times and I may get slammed for posting without searching, but, hey, I'm lazy!
Bikes: '87 Paramount & '02 Scapin EOS3
You only put underwear or jock strap, etc., under your bibs/shorts if you want lots of chaffing and sores. The only thing that should be between you and your chamios is some Chamois Butter, if you use such. Helps stop saddles sores and such.
Geezer Member
Bikes: Airborne, LeMond, Bianchi CX, Volae Century, Redline 925 (fixed) and a Burley Tandem.
None of my bibs stop me from taking a leak in the normal way (standing that is) they have plenty of flex to pull them down in front. In my experience the only people that prefer shorts to bibs are people that have never tried bibs. It's not that shorts are uncomfortable it's just that bibs are so comfortable.
Trekrider, I think the bibs I have are the Performance Elite Multi-L. I was told that I'd be happiest with the Coolmax shoulder straps, and that was correct. Performance has the Elite Multi-L, and the Ultra Bibs, which both have all material above the normal short as Coolmax. For the urinating problem, I notice the models in the Performance catalog wearing sleeveless T-shirts Under the bib straps, which would allow sliding the straps off the shoulder and going like we would in regular shorts.
Trekrider. I wear bib shorts from www.Probikekit.com I believe they produce their own in house cycle clothing.
The "Coolmax" I purchased from them I can highly recommend
