Creak that's driving me nuts
I have a creak that only happens when I really hammer/stand on pedals when climbing. The sound seems to happen with every rotation of the crank. Seems to creak a bit more when my left leg pushes down. This isn't coming from the seat/handle bar area.
So here's what I did try to prevent this creak:
-re-cabled my bike
-every bolt cleaned, re-lubed
-removed cranks/bb, re-lubed splines on octalink BB, lots of anti seize on BB threads. BB torqued to 50 ft lbs, cranks to 40 ft lbs. This is a sealed BB, no adjustment.
-pedals removed, cleaned re-greased threads, not loose on crank
-checked cleats for looseness, lubed cleat mounting bolts
-re-lubed seat post, alumin/alumin contact
-checked tension on wheels, all spokes within 5% of each other
-tried 3 cassettes
-rebuild hubs. No binding, spin smooth.
When the creak started I started to diagnose, which lead to a worn chain. I had a dura ace chain. I replaced it with Sram 991HP chain. I looked on sheldon's site at worn ring/cassette pictures. I don't seem to exhibit signs of wear.
After doing all the above, the sound has gotten less profound. Before I found the chain issue, I thought it was my BB. I took it out, cleaned, re-torqued. If I remember correctly, the creak did decrease a bit. Is this BB related? It seems to spin smooth. Any ideas?
-re-cabled my bike
-tried 3 cassettes
Quoted: 2026 Post(s)
Liked 1,095 Times
Did you check the chainring bolts?
change the quick releases in both wheels. If you have some in AL or Steel do a test with them I'm sure the creack noise will stop right away. New QRs are made of AL with plastic parts so they tend to go bad, put some oil between the plastic parts or get a new pair or QRs.
Hope this solve your problem.
UM
UM
Industry guy
Is this a carbon fiber frame with a bolted together rear triangle?
+1 on the QR idea...grease the contact points between the dropouts and the hubs on one side and the QR on the other...front and back.
In the wind
I had a creak very much like yours last year. I tried most of the things you did except for the hubs and cassette replacement. In the end, I gave up and took it into the LBS. The solution?
More torque on the pedals.
Take off, grease, and reinstall the rear derailleur hanger. A lot of them are not really up to spec so they move around a bit. Don't know Scott specifically but I've seen a few of them.
cdr
cdr
chicken pecker
Bikes: everything except a roadbike
I forgot to mention that some cracks are on the inside of the frame or bottom bracket. You might not be able to see them. Ask your LBS.
Well, here's an update. Problem solved
Took the wheels off. Put a bit of grease on the drop outs. Also put some grease on the hubs/sqewers where they contact the drop outs. Now my bike is silent
