Help: need parts for my Zefal pump
Old 04-30-08 | 02:35 PM
The head on my Zefal Husky floor pump won't hold an airtight seal between the pump head and a schrader valve or presta adapter anymore. The Zefal website says there's supposedly a replacement rubber ring available, or replacement head but I can't find anyone who sells those. So, I either need to find a compatible pump head or hose. Has anyone found a U.S. source for Zefal pump parts, or used/adapted a head or hose from another manufacturer's pump on a Zefal? Let me know.
Thanks,
Rich
Richbiker is offline
Reply
Old 05-02-08 | 06:13 PM
BloomingCyclist's Avatar
It Takes Two
Bikes: 1973 Chiappini w/ Campy New Record, 2004 Kestrel Talon w/ Campy Chorus, 2006 Santana Team Niobium
I believe this place (XX Cycle) ships anywhere including the US - here's a link to the Zefal Husky parts page.
https://www.xxcycle.com/parts-pumps-foot,en.php
I have used the Topeak replacement head & hose which is more readily available on three different brands of floor pumps so it may do fine on your Zefal.
Bloomington, IN
BloomingCyclist is offline
Reply
Old 05-02-08 | 06:28 PM
20 Anniversary
Bikes: 2 many
Did you already tighten the outer ring a little bit that adjusts the diameter of the hole to make up for this common problem?
2manybikes is offline
Reply
Old 05-06-08 | 03:37 AM
Bikes: Trek T200 plus enough others to fill a large shed
When this happened on my speclialized pump I upgraded to a new head. I got a Blackburn head which fits presta and schraeder valves, which is handy on the rare occasions when it's needed. It screwed straight into the Specialized base, which would suggest that I was either lucky or manufacturers tend to use the same size for hose attachments.
mrfish is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
