rob roy owners, what is your rear spacing and hub/skewer combo?
Old 05-01-08 | 06:54 PM
xccx's Avatar
Bikes: 2 Felt F1X's, Surly Steamroller Fixed / Free, 2007 IF Crown Jewel, 2007 IF Planet X Singlespeed
i'm trying to get some answers on what hubs ppl use and if they have had luck (good or bad) using a quick release on track ends.
thanks in advance
xccx is offline
Reply
Old 05-02-08 | 07:38 AM
dirtyphotons's Avatar
antisocialite
i have had much good luck with qr and track ends. i usually use a mountain skewer and get it tight enough that you start to feel resistance when the qr is 90 degrees from the plane of the wheel.
dirtyphotons is offline
Reply
Old 05-02-08 | 09:03 AM
Titanium Club Membership
15 Anniversary
Shimano or Campy or Mavic QRs all work for me. But these are the old school style with the lever coming out the side of the cam body. Them new fangled straight-lever things don't work worth a damn. Okay, they mostly work well enough for vertical dropouts and forks with lawyer lips, mostly.
Ronsonic is offline
Reply
Old 05-02-08 | 04:59 PM
xccx's Avatar
thanks, but what is the spacing? i cant use mtn skewers because my rear spacing is 130
xccx is offline
Reply
Old 05-02-08 | 05:56 PM
Elisdad's Avatar
Bike rider
Bikes: Redline D460, Redline Monocog Flight 29er, IRO Rob Roy, Specialized P1
From IRO's site:
Rear Dropout 132.5mm
Your road hubs should be fine, as will mtn hubs.
Elisdad is offline
Reply
Old 05-02-08 | 06:09 PM
Psydotek's Avatar
Body By Nintendo
From: Videogames ruined my life. Good thing i have 2 extra lives.
Bikes: Giant TCR2, Giant TCX, IRO BFSSFG SE, Salsa Casseroll, IRO Rob Roy.
What about a quick release with some MKS chain tugs or Surly Tuggnuts?
Originally Posted by jsharr
A girl once asked me to give her twelve inches and make it hurt. I had to make love to her 3 times and then punch her in the nose.
Psydotek is offline
Reply
Old 05-04-08 | 08:54 AM
15 Anniversary
The MTB skewers I've seen have enough thread to work with 130, but there is a bit of extra axle sticking out the end - uh, about 5mm I'd guess. I don't know that there is any other difference between road and MTB skewers. Anyway you'll want steel skewers, this is no place for titanium or other lightweight stuff.
Just a basic skewer like the one Tullio Campagnolo invented back in the 30s for use with bikes that had track ends.
Ronsonic is offline
Reply
Old 05-05-08 | 08:09 AM
antisocialite
i use mtb (135) skewers with road (130) hubs. long as there's enough threading it's no problem.
Reply
Old 05-05-08 | 01:06 PM
Originally Posted by Elisdad
From IRO's site:
The new IRO site lists the rear spacing as 130mm. Better call and ask to be sure.
https://shop.irocycle.com/shop/produc...2&cat=1&page=1
Cyclist0383 is offline
Reply
Old 05-05-08 | 06:50 PM
Elisdad's Avatar
Bike rider
I just shot IRO a message through their web form on the site. It'd be nice to be sure that I can use the mtn hubs that I have been planning on using for my group buy frame.
Elisdad is offline
Reply
Old 05-05-08 | 10:41 PM
I just checked my group buy frame and it appears to lean more towards the 132.5mm side of things, coming in at almost 132mm on my digital calipers.
Reply
Old 05-06-08 | 05:02 AM
Elisdad's Avatar
Bike rider
Tony replied and said the spacing was 130, but he could fit a 135 in the dropouts. I tried it last night with an Alex wheel that I have as well as an old 26" MTN wheel. Both wheels fit, but the fit was a little better when using the MTN wheel with 135 spacing.
Elisdad is offline
Reply
Old 05-06-08 | 02:48 PM
mconlonx's Avatar
Nexus 8 hub is supposed to be somewhere between 132 and 133, and it fit the RR frame like it was made for it...
mconlonx is offline
Reply
Old 05-06-08 | 04:00 PM
doctordan's Avatar
chasing down blood sugars
Bikes: too numerous to count
My Phil Wood 135mm mtn hub fits just fine. My RR group buy measured 132.5 mm give or take a tenth.
doctordan is offline
Reply
Old 05-07-08 | 10:06 AM
15 Anniversary
Even if the RR were a 130, which it isn't, it does run a bit wide, resetting for a 5mm difference is essentially trivial. Find the oldest bike shop in town and let them do it.
Ronsonic is offline
Reply
Old 05-07-08 | 03:55 PM
xccx's Avatar
perhaps a follow up question:
is there any danger or performance issues with running a 135 hub in 130 track ends?
also,
what do you mean by "resetting for a 5mm difference?"
thanks again
xccx is offline
Reply
Old 05-08-08 | 09:16 AM
15 Anniversary
The rear of a steel frame can be adjusted for a different axle width. The process is called "resetting" you can call it "bending" if you like but that doesn't sound as nice and technical. Two parts to it: spreading the rear triangles to the correct width and making sure the dropouts or track ends are parallel. It's that last thing that'll get you when you stuff in the wrong width axle. If the ends aren't close to parallel, the wheel will tend to slip and over stress the skewers and axles and bearings if you crank down hard enough to make up for it.
Since the RR is designed to take either 130 and 135 wheels it should have none of these problems. Clamp it down and ride.
Ronsonic is offline
Reply
Old 05-08-08 | 09:41 AM
yes, you can use 135 or 130 spacing on the rr
I have put on my mt hubs 135 and also my track hubs(120mm with 10mm spacers) , both work fine
doco is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
