Sag w/ low end forks vs high end forks
Old 05-04-08, 03:48 PM
I wanted to adjust the sag on my RockSock Dart2 to 20mm but noticed that it only goes down to about 15mm. Does anyone have the same or a similar fork and experienced the same thing?
With higher end forks can you control more variation with the sag?
bank5 is offline
Old 05-05-08, 06:19 PM
The Dart series use coil springs...so to get more sag, you'd either need to weigh more, or use a lighter weight spring. The higher end forks mostly use air springs...you can just use a lower pressure to get more sag...
kramnnim is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
