barrel adjuster dilemma...
I have a two pairs of nice 80's vintage single pivot brake calipers (Gran Compe Royal Compe and Shimano 600) but neither pair has a good set of barrel adjusters. I looked around here, and Google, and it seems the only replacement is a set from Campagnolo at $25 each! At $50 for a pair of them I can buy some pretty decent brakes - are these brakes really pretty much worthless without these adjusters? I do have one set of adjusters, but the threads are beat up on them and they won't 'adjust' anymore.
Sell all 4 on eBay for ???, or keep and wait and see??? Any suggestions?
They both use the Campagnolo NR type adjusters. I wish the arms were threaded to accept adjusters from newer brakes, but they have a 'D' shaped hole that the adjuster sits in. With the cables off the bike the adjusters simply fall out of the hole. No one has ever drilled the hole out a little then tapped it to accept the threaded in adjusters?
Thanks! I have the 6207 version, and what you describe is exactly what these adjusters are doing. I'll try the liquid wrench.
For aluminum pieces bonded together, soak in an ammonium solution, this will dissolve the aluminum oxide and allow you to separate the pieces.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Speaking of taps... is this the thread size of the 'regular threaded adjuster'?
