Pitch or Patch
Let's ride to the pub!
Pitch or Patch
Do you patch tubes?
Of course I did, back in the day, when I was a student, and lived on my teaching assistant stipend...and then after that, I had a grown up job, and I didn't have any flat tires for several decades, except on my car, but that's different.
So now, I'm riding again, mostly on the tandem, and the tandem captain switches out the tube when there's a flat. So I always say, because I believe it, that I will patch those tubes, someday...but the collection keeps growing.
I ALWAYS patched tubes, sometimes I even patched them without taking them all the way off the wheel...
and they were FINE...
So, should I get patching?
And, are there better patch kits than there were back in 19-mumbling-erother?
What do you do?
What do you do?
I patch 'em unless they're really shot or I'm in a terrible hurry. One trick that I found that makes things much easier is to use alcohol to clean the affected area instead of sandpaper/rasp. The only hassle now is waiting for the glue to dry once it's applied. I've never had a patch fail and with 3 kids, I'd go broke buying new tubes for everyone's bikes.
Ride Daddy Ride
Bikes: 1983 Trek 720; 1983 Trek 620; 1989 Gi Cannondale Bad Boy Ultra; LeMond Victoire; Bike Friday Pocket Rocket Pro
No doubt that's the right choice for any number of reasons, but with one or two flats every couple of years, I've gotten lazy, and tend to just replace the punctured tube with a new one and never get around to fixing the old one.
"Light it up, Popo." --Levi Leipheimer
- Install new tube on the road.
- Bring flat home and tie it in a knot so that I remember it has a flat
- Throw it on the "patch" pile
- Once a year, throw the patch pile away.
Bikes: 1986 Univega Grand Touring; 1983 Puch A/D Pacifica; 2006 LeMond Sarthe
A am adopting this policy. To toss them seems wasteful. Today I went for a ride and got 2 flats - after fixing another one from yesterday that happened so close to home that I just carried the bike a block to my house. I had to patch the second flat because I only had one tube with me. A seam seemed to have split in the tube and I used two patches to cover it, but it held. The patches work fine, and I now see no excuse for not using them. Come to think of it, I could spend all the money I save buying tubes and patch kits an invest in some good quality tubes and "puncture proof" tires. But, that's another topic entirely...
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
I hate the wastefulness of tossing a punctured tube, but today's tubes simply do not seem to last as long as those of yesteryear. I have had several tubes split along a seam, and others have failed at the base of the Presta valve stem, a problem I used to have only if I put a Presta tube on a rim drilled for a Schraeder valve, without a washer or boot.
I would rather carry a brand-new spare tube with confidence and ride on a patched one.
Bikes: Co-Motion Speedster, Giant FCR2, Surly LHT, Surly Crosscheck
I'm Malkin's tandem captain (but she's my Rear Admiral!). I think patching the pile with quality glue-ons is a good idea--maybe I'll arrange a party. I also appreciate the suggestion of using alcohol rather than sandpaper. We'll try that.
And I'll always carry at least one new tube. Purchased in quantity from an online dealer, tubes are about $3 each. It's really a pity that the cost to replace is arguably less (including time and materials) than the cost to repair. Chalk it up to our throw-away culture.
"One or two flats every couple of years..." Wow.
We've had 3 (or is it 4) already this year. Maybe it's just a Utah thing.
Cheers!
Cheers!
2008 Red Co-Motion Speedster Co-pilot (Redster)
2009 Surly LHT (captain's commuter)
2009 Surly Crosscheck (stoker's road bike)
2007 Giant FCR2W (stoker's commuter)
1980's NOS Legnano (stoker's toy)
1970's Stella rebuilt as fixed-gear (captain's toy)
Bikes: Bianchi Road Bike & Gary Fisher Mountain Bike
This raises an interesting question. Who has the biggest 'patch' pile?
Mine only has 3 in it, but from some of your responses I am expecting something quite a bit bigger.
Liked 6 Times
Scott P
Bend, OR
Erect member since 1953
Bikes: Trek 520 Grando, Roubaix Expert, Motobecane Ti Century Elite turned commuter, Some old French thing gone fixie
Quoted: 121 Post(s)
Liked 38 Times
Rema still makes the best patches, same as in 19XX. You can get a box of 100, then use any old rubber cement and save a ton of cash. Those small glue tubes always dry up on me.
The leaks I really hate are the super small ones I can't find without water.
Anyway, I'm a patch guy.
Quoted: 1572 Post(s)
Liked 643 Times
Me too. I don't think that I've got any tubes with holes in them downstairs, but I've got a good assortment of both new and patched tubes.
Time for a change.
Liked 5 Times
I know what I should do- Patch when the puncture occurs. But just a few pointers. Put the Tyre label over the valve when you fit the tyre. Then when you locate the hole in the tube- it will give you an indication of where- the Flint- Thorn- lump of Glass is in the tyre so you can inspect the tyre and get rid of the offending item. Keep the tube well talced and it is easier to fit- and as to patching- it only takes a couple of minutes- in fact less as to change a tube you have to get the tube out- put a bit of air in it- Check the tyre for offending items from the inside (which you should do in any case) and the OLD tube that you are going to forget to repair before the next ride- has to be rolled up to fit back in the wedge.
All that goes by the board as the last 3 punctures I have had all been in the rain. And trying to patch a wet tube is not easy.
Spike Milligan
Spike Milligan
Not that you need another opinion on this, but I'm a patcher for at least a couple of reasons.
First is economic. A new tube costs, what, about five bucks? I work seven minutes to make five bucks (before taxes). I can patch a tube in less than half that time, even if you don't count the time required to go to the LBS and buy a new one.
Then there's the landfill issue: Why should I toss a tube that will be better than new after I fix it (the patch is stronger than the original rubber)? It's a small thing individually, but not when multiplied by the 35+ years I've been riding. Plus needless waste just pisses me off on principle--it's one of the problems with our self-centered society.
OK, off the soapbox. FWIW, though, in almost 40 years of riding as an adult, surely hundreds of flat tires (I had nine on a century one time), I can remember only two patch failures, and one of those was my fault.
Hey, thanks everyone!
Our patch pile has a bunch more than 3, some of them fit bikes we don't even have anymore. And I'd never be able to toss them--I'd have to work out some nifty way to recycle them in to rugs or casual furniture or cat toys or something. Fortunately, the bike collective will take them too.
But you've all got me convinced; I'll patch.
Roadkill
Bikes: 2002 Lightspeed Classic; 2010 Pedalforce RS
I used to patch until there wasn't room for more. A couple of times I've gotten burned when patch jobs failed when I took them out of my saddlebag out on the road somewhere.
Lately I've had less flats and have just gotten lazy, so now I patch a tube only once, maybe twice. Also, now I patch a punctured tube and put it right back on the bike as soon as I get home. The patched tube has to hold air overnight before I ride on it. The spare tube I carry is always unpatched or at least has been proven to hold air a few days if patched.
Quoted: 8 Post(s)
Liked 10 Times
Do you use glue-on or glueless patches? I have had limited success with the latter.
I've never used glueless patches, never could figure out what is so difficult about glue-on patches.
I always use talcum on a fresh patch.
I've had a few tubes split at a seam but overall, luck has been on my side.
Uh-oh, to talc or not to talc, a whole new argument.
gone ride'n
Bikes: Simoncini, Gary Fisher, Specialized Tarmac
Timely post. I don't get many flats - maybe 2 a year on the road since I changed over to Gatorskins a few years back and check the pressure every 2 or three times out. I got a flat last Sunday on the back and when I inspected the tire (starting the third season on it) I found it had several shards of glass in it so when I got home I pulled out a new tire. The Gatorskin with the kevlar bead is always a bear to get on new the first few times so I patched the tube knowing that I would pinch it putting it on the first time or two. Well after two trys and three patches the tire went on without a new hole in the tube but then I noticed I had it on backwards - gatorskins like to rotate in a specific direction. Off again/on again - but this time I put a new tube back in and was successful in the repair.
So - I occassionally patch but mostly pitch.
Geezer Member
Bikes: Airborne, LeMond, Bianchi CX, Volae Century, Redline 925 (fixed) and a Burley Tandem.
I buy new tires and tubes every spring..... I know, I know.... sounds wastefull... but I give my "old" ones to a kid down the street that rides on a tight budget.
Carpe who?
Carpe who?
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
What do you use for talc? I've been using baby powder with cornstarch, but figure there is probably something better to use.
So I went to the neighborhood bike store to buy a patch kit for our tube patching party. The kid behind the counter looked at me as if I had asked him for replacement parts for my spoon brake! He finally sold me a store-branded patch kit that included about .00001 oz. of glue and 8 tiny patches after railing on and on about Air-Lock tubes by Specialized.
The follow-up question is this: Do you use Air-Lock (or some other version of slime-infused tube)? Why or why not?
Cheers!
Cheers!
Quoted: 8 Post(s)
Liked 10 Times
I'm also one who talcs the whole tube when it's new, and the inside of a new tire as well.
Quoted: 8 Post(s)
Liked 10 Times
Cheers!
Cheers!
Tubes, tires, glue, talc, etc. - all part of the lore of cycling, if you ask me.
I wouldn't let "Slime" get within 100 feet of any bike of mine.
"Hey you kids, get off my grass!"
