New frame for an Xtracycle
Urban Assault Cyclist
I have an Xtracycle on a Del Sol Lowboy frame right now. It's similar to the Electra Townie. Problem is that the laid-back geometry is no longer right for me. So, I'm looking to hook it all up to a new frame. I have a Specialized Rockhopper, but the seat stays are tapered. The issue that brings up is with the Bobike Maxi seat. The mounts on the seat stays slip down. So, I'm looking for a good solid frame that does not have tapered seat stays. Any ideas?
Part-time epistemologist
A narrative on bicycle driving.
Beer-fueled
Bikes: Giant Rincon (199x), 2005 Trek 1000, 19?? "Apollo Sport 10" by Kuwahara
Surly's Instigator doesn't have tapered seatstays and is burly as all get-out. My Xtracycle is a pre-owned Instigator frame with the Xtra, a Surly Instigator fork (rigid) and some balloon tires (Conti Town & Country). Plush and a lot more nimble than I thought it would be.
procrastinating member
I use an early 90s Iguana Giant (rigid MTB). Works great.
The Bobike Maxi mounts in three places- the upper with either a clamp on the upper end of the seatstays (near the upper cluster) or an adapter which clamps to the seattube, and the two lower points are clamps on each seatstay about halfway down- I suspect it is these lower clamps that are slipping...
Liked 10 Times
https://www.bobike.nl/products/en/atb...uismontage.htm
Could this be of help?
Originally Posted by Bobike.nl
A separate ATB bracket is available for the Bobike maxi+, maxi and junior. This bracket allows the seat to be mounted on bicycles with a non-standard frame. The Bobike junior then sits slightly further from the saddle.
