Tires for crushed limestone touring, part II
Bikes: "Hildy", a Novara Randonee touring bike; a 16-speed Bike Friday Tikit; and a Specialized Stumpjumper frame-based built-up MTB, now serving as the kid-carrier, grocery-getter.
Quoted: 11 Post(s)
Things have changed since I last posted about this thread about MTB knobbies or slicks on the Pittsburgh to DC trails. The general consensus is that 26" semi slicks would do fine on the crushed limestone and gravel.
The mountain bike lost an argument with a car, and I picked up a Novara Randonee with 700/32 tires. I'm thinking that the differenc in tire width will change matters a little bit.
So: Cross tires with a mild tread? Something along these lines:
Tour Journals, Blog, ride pix
My bands:
My bands:
- Uke On! - ukulele duo - Videos
- Ukulele Abyss - ukulele cover videos - Videos
- Baroque and Hungry's (Celtic fusion) full-length studio album Mended.
- Artistic Differences - 8-track EP Dreams of Bile and Blood.
My guess is that the stock tire (Vittoria Randonneur 700x32) on the Novara Randonee should be fine for the GAP and C&O.
Quoted: 163 Post(s)
I don't know what that tire you pictured is, but it looks a lot like the Conti TravelContact, which has slick in the middle and knobs on the sides. I did fine with that on packed dirt and packed gravel. I rode some of the C&O a few years ago with the stock tires from my 50 which had a light inverse tread, no knobs. You should be fine with what you posted above or similar. I would go wider if you're going to swap tires.
edit, i mean wider than the stock 32s for the towpath. the contis are 35s
Agreed. If the world of marketing only offered one or two bicycle tires to us, the net effect on touring would be unmeasurable. Almost any other component decision is more important -- the color of your cable housing, for example.
Quoted: 11 Post(s)
Obsessing about tires may be obsessive, but it's fun!
My bands:
My bands:
Guest
Posts: n/a
Quoted: Post(s)
Bikes: Novara Safari, Kona Fire Mountain
I know that no one has talked about the Continental Town/Country in this thread yet, but I feel a need to post about them. A few months ago I loved them and posted good things about them on similar forums. I said that they were rugged and solid on all types of trails, but I am on my TransAm ride right now and I have ditched my Contis. I recommend others to steer clear of them.
The problem I have had is weak sidewalls. I had one tire blowout (while the bike was unloaded and not rolling!) and the other tire started to bubble even with patches on the inside and outside. Even when you take them off of the bike the sides feel flimsy and not to be trusted. They don't feel like they would be a good touring tire at all!
The Serfas Drifter is a similar tire that has felt very solid, and I'm using Michelin City tires on my Novara Safari right now. Both of them have been great, and they do well on crushed limestone and gravel. They are too big for the Rand, I think, but I want to throw out my couple of pennies anyway. Don't go Conti. Otherwise, have a great time on the GAP and C&O...great trails!
-cpt
Links for the tires...these are REI links, but you can buy them lots of places.
Drifter- https://www.rei.com/product/724622
Michelin City- https://www.rei.com/product/768732
-cpt
Quoted: 11 Post(s)
My bands:
My bands:
The Wheel is Turning
Bikes: '05 Novara (REI) Bonanza
These...
Specialized Crossroads Armadillo
I was running Conti Town & Country tires for the longest time but they have gotten crappier so I asked my LBS for a recommendation. They hooked me up with the Crossroads for $65/pair and these things will ride over anything. There is a lot of glass and shrapnel on my commute and the Armadillo casing combined with the beefy tread handles it all. And they are a fast, fast tire; especially for something with that much tread.
https://www.downtheroad.org/Equipment...ring_Tires.htm seems to say that Contintental isn't bad, just their Town & Country tire. I have some Travel Contacts. They seem durable so far. However, since the tread is only on the edge, they feel like a road tire when I'm trying to climb a dirt or gravel road going uphill, and a knobby tire when I'm trying to corner on a paved road.
Bikes: Cruzbike Conversion
limestone?
I think that is the largest tire I can put on my OCR2 for this up and coming adventure.
Bill
My partner, teenage son and I did the Erie canal tour last summer with a lot of limestone trail-
that dust just seemed to penetrate everything. We each had Schwalbe marathon tires- they had
50x559, I had 42x622. The tires were great, no problems, good traction and wear.
Out fishing with Annie on his lap, a cigar in one hand and a ginger ale in the other, watching the sunset.
Bikes: Techna Wheelchair and a Sun EZ 3 Recumbent Trike
Quoted: 9 Post(s)
Liked 22 Times
32 mm wide tires can be run fine. On the firetrails up in Michigan, on the UP, I just aired down to 80 PSI for a little better flotation on soft, sandy, gravelly surfaces. Once I was back on pavement, I just aired back up to 100 PSI.
. “He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.”- Fredrick Nietzsche
"We can judge the heart of a man by his treatment of animals." - Immanuel Kant
