Go Back  Bike Forums > Bike Forums > Clydesdales/Athenas (200+ lb / 91+ kg)
how do i find out calories burned using cyclo computer?
Clydesdales/Athenas (200+ lb / 91+ kg) Looking to lose that spare tire? Ideal weight 200+? Frustrated being a large cyclist in a sport geared for the ultra-light? Learn about the bikes and parts that can take the abuse of a heavier cyclist, how to keep your body going while losing the weight, and get support from others who've been successful.
Old 05-19-08 | 07:29 AM
moosehead's Avatar
Bikes: Specialized Expedition Sport '08
I just got back from a ride. I'm wanting to have a fair estimate of what my calories burned are. The trip was 1.24 miles long and i went a max of 12.4 mph, with an average of about 8mph. The average speed might be a little higher but i'll just say 8 since i'm pretty sure i'm doing that all the time (reset my computer too soon to tell).
thank you
moosehead is offline
Reply
Old 05-19-08 | 08:11 AM
Bikes: Steelman road bike, '81 Schwinn Le Tour single speed,
https://www.mapmyride.com/ has a calorie counting function.
misterE0 is offline
Reply
Old 05-19-08 | 08:25 AM
Tom Stormcrowe's Avatar
Out fishing with Annie on his lap, a cigar in one hand and a ginger ale in the other, watching the sunset.
Bikes: Techna Wheelchair and a Sun EZ 3 Recumbent Trike
https://bikecalculator.com/veloUS.html
. “He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.”- Fredrick Nietzsche
"We can judge the heart of a man by his treatment of animals." - Immanuel Kant
Tom Stormcrowe is offline
Reply
Old 05-19-08 | 04:14 PM
Mazama's Avatar
Bikezilla
Bikes: Co-Motion Mazama
Originally Posted by Tom Stormcrowe
Tom, what do you put in the "Power" category?
Mazama is offline
Reply
Old 05-19-08 | 04:34 PM
If you stay at the default setting, it will give you a speed of 14 MPH, so, that could be considered a light to moderate effort.
400 watt output gives you a 25 MPH on flat ground.
Most riders actually average around 250 watt output average with peaks and valleys of 100 and 400 respectively.
Even if you stay at the default setting,though, it will give you a starting baseline. I'll look for something to estimate the wattage output for a cyclist, though.
Reply
Old 05-21-08 | 01:21 AM
Mazama's Avatar
Bikezilla
Default works for me. My bike has never seen anything over 22MPH even going down a bridge. I can't imagine doing 25 MPH on flat ground.
Thanks for the information. You are all-knowing.
Mazama is offline
Reply
Old 05-21-08 | 09:10 AM
Tri 4 chiropractic studen
Bikes: Hopefully a Giant FCR1 or a Trek 7.5FX
I imagine the calories would be higher if you are on a heavy mountain bike compared to a light road bike. Do these calculators take that into account?
chirojeremy is offline
Reply
Old 05-21-08 | 12:46 PM
This calculator I set allows variables like bike/rider weight, tire type and size, etc.
Reply
Old 05-21-08 | 07:31 PM
efolsom's Avatar
Old enough to know better
Bikes: pilot 2.1
Tom
Play with this one:
https://www.kreuzotter.de/english/espeed.htm
efolsom is offline
Reply
Old 05-21-08 | 07:55 PM
That's the one I normally use, but the link had been broken. It's good to see they have it fixed. You can bet I'll be saving it as an HTML document so I can host it on my internal network server for my own use now, in case the link tanks again.
Reply
Old 05-21-08 | 08:08 PM
jaxgtr's Avatar
Titanium Club Membership
Sheldon Brown Memorial - Titanium
15 Anniversary
Bikes: Trek Checkmate, Lynskey Elysium, Trek FX 5 Sport
Just don't use the Garmin calculator, it's hideously high
Brian | 2025 Trek Checkmate | 2025 Lynskey Elysium | 2022 Trek FX Sport 5
Originally Posted by AEO
you should learn to embrace change, and mock it's failings every step of the way.
jaxgtr is offline
Reply
Old 05-21-08 | 09:15 PM
Bikes: Litespeed Ultimate and Tuscany
Check this out:
https://estore.websitepros.com/193951...cle/Detail.bok
mitchel is offline
Reply
Old 05-22-08 | 06:08 AM
Wogster's Avatar
Bikes: Old Bike: 1975 Raleigh Delta, New Bike: 2004 Norco Bushpilot
They have some other calculators on the right side of the screen, like this one for metric units, or this one if you want to use US units.
In these you supply speed, and it provides watts. The difficulty in all of these calculators, is what to do about grade, if I start and end at the same place, then effectively up and down hills match up, but I know that hauling butt up some of the big hills uses way more energy then you gain from going down the same hill. Wind is the same deal, a strong head wind is much more of a hindrance then a strong tail wind.....
Wogster is offline
Reply
Old 05-22-08 | 07:10 AM
When you have a single hill, I've always estimated the average grade by starting elevation vs ending elevation. That way, if nothing else, you underestimate the required output.
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
