Brakes ahhh help!!!
Brakes ahhh help!!!
Attemtping to build an electrathon car with my fellow classmates. I am responsible for the brakes and am having trouble deciding what type would be best to stop a 300-400 lb car going 40 mph. I believe disk would be best but if anyone happens to know something that would be better or even a good web site to buy brakes please help!!
Elitist Jackass
Bikes: Cannondale 2.8, Specialized S-works E5 road, GT Talera
old motorcycle parts is the best, most bikes weigh at least 300lbs. You can get old mechanical hydraulic systems off of any old bike. With steel braided lines, and 6-piston calipers on a double front disc, I could slow to 90 from 160 in just couple seconds using 2 fingers.
Bikes: Manitou SS, Trek 69er SS, Fisher Cake DLX1, Breezer Beltway 8
If you need to keep things really light (although the car seems heavy), then you should look to bicycle disc brakes. The issue with creation of the mounting studs will be interesting, as will the method by which you attach the rotors to the wheels you use. If you use bicycle wheels, already, just use disc-hubs and then look at getting some 8" rotor, hydraulic brakes, such as those made by Hope, Hayes, Magura or Avid.
Smart
