Singlespeed with Vertical Dropouts and No Tensioner???
Bikes: Transition Bottlerocket, 2006 Lemond Fillmore
Hey everyone, I have an old Centurion CompTA with vertical droupouts and I wanted to convert it to a singlespeed, however the wheel I have is a quick release (with a casette). .
Is there a way I can use this same wheel (with the skewers) and NOT have to use a chain tensioner? Please say yes.
Bikes: 2014 Trek Domane 5.2, 1985 Pinarello Treviso, 1990 Gardin Shred, 2006 Bianchi San Jose
Quoted: 62 Post(s)
Liked 28 Times
Why yes, but you'll need an eccentric bottom bracket. Or you could try the magic gear combo. and maybe a half link to get you there.
Not sure I'd want to use a quick release on my rear hub, though.
Read this:
https://sheldonbrown.com/singlespeed.html
Read this:
What would I do about this problem if I had a horizontal dropout?
Guy on a Bike
Bikes: Chromoly Univega with Nexus Hub
Unless you want to ride fixed, a chain tensioner really isn't that bad to have. I wouldn't reccomend riding fixed with a quickrelease though. (If you backpedaled quickly, you could rip your rear wheel right out.)
+1 for the eccentric bottom bracket. You might also consider a half chain link
Guy on a Bike
With a horizontal dropout, you probably have enough adjustability to make your chain as tight as you need it. If you don't quite have enough, a half link would most likely solve your problem.
DNPAIMFB
Bikes: Titus El Guapo, Misfit diSSent, Cervelo Soloist Carbon, Wabi Lightning, et al.
Whoa - deja vu: https://eehouse.org/fixin/formfmu.php
