Araya PX-45 rim
Araya PX-45 rim
Old 05-25-08 | 09:57 PM
Araya PX-45 rim
I recently built my first wheel with an Araya PX-45 rim that I bought used and a Shimano hub. However, once I got the wheel built I realized the braking surface was concave. In researching this on the net I found that Araya built some rims intentionally with concave braking surfaces. Does anyone know if this particular rim was built this way or is it just worn out and should be replaced?
Thanks so much in advance......Bumbliwa
Oh, and by the way it's a 700c wheel....
Bumbliwa is offline
Reply
Old 08-14-17 | 03:51 PM
canklecat's Avatar
10 Anniversary
Old thread but since the question comes up occasionally... yup, the Araya PX-45 rim (link to Araya Japan archives) was made with concave braking surface, as were several other Araya rims from that era, the early 1990s. The theory was that it provided better braking with less weight but some compromise to strength. The Araya catalog still recommended stronger double wall non-concave rims for more demanding downhill and other mountain biking activities.
My 1993 Univega Via Carisma came with the original Araya PX-45 rims. The bike was essentially marketed as what would later be called a hybrid. Good single wall rims advertised for light duty riding. Mine have held up to gravel, chipseal and rough rural pavement and some light off road riding. The rear rim was warped in a sideways skid on loose gravel over a freshly chipsealed road -- no crash, just a sideways skid and sudden stop. A bike shop mechanic was able to straighten the rim in a few minutes. Rides just fine.
canklecat is offline
Reply
Old 08-14-17 | 08:57 PM
Jiggle's Avatar
Bikes: BH, Cervelo, Cube, Canyon
I just can't wrap my mind around how that would be a benefit. Maximum bending stress is on the surface of a beam, and making it thinner brings the point of maximum stress closer to the neutral axis, reducing stiffness. The thicker upper and lower would add nothing because the reaction force is at the thinnest point.
Might as well just make the whole sidewall thin.
Which is what we see in modern rims.
Jiggle is offline
Reply
Old 08-14-17 | 10:23 PM
ThermionicScott's Avatar
10 Anniversary
There must be something to that "concave rim" thing, as Araya makes the VP-20 to this day.
I wouldn't use one, though -- I like being able to judge rim wear by feeling the sidewalls for concavity.
ThermionicScott is offline
Reply
Old 08-14-17 | 11:45 PM
Jiggle's Avatar
oh, a company does it so there must be something to it. sure. wink wink.
Jiggle is offline
Reply
Old 08-15-17 | 12:24 AM
canklecat's Avatar
10 Anniversary
Yeah, who knows whether concave rims offered any real advantage, or whether it was a fad like Univega's cool looking bi-axial oval frames.
The tricky bit is finding brake pads that fit properly.
I started out with Kool Stop Eagle 2 pads on this particular bike. Good pads, easy to toe-in (the plow tip is self aligning), but tricky to align perfectly to clear the tire while maximizing contact. The pads were just a bit wider than I'd like for the Araya PX-45 rims. And too thick to clear the fork enough to easily drop the wheel with slightly oversized tires.
So I switched the front set to Jagwire Mountain Sport 70mm pads for cantilever brakes. Perfect. Thinner, to fit the rim perfectly, snugged into the concave surface. Curved to match the rim. Longer than the Kool Stops. Overall more effective brakes than Kool Stops for this particular rim. I kept the Kool Stops on the rear wheel.
Reply
Old 08-15-17 | 10:02 AM
hokiefyd's Avatar
Titanium Club Membership
5 Anniversary
Bikes: More bikes than riders
I have Araya VP-20 rims on a 1995 mountain bike with concave braking surfaces. Some of Trek's Matrix wheels also had this. Trek's materials said it was to help fight brake shoe dive. I'm not sure how effective it would be at that, but I guess it makes sense in theory.
hokiefyd is offline
Reply
Old 08-15-17 | 10:47 AM
JohnDThompson's Avatar
Old fart
20 Anniversary
Community Builder
Perhaps the intent was to increase the surface area of the brake track?
JohnDThompson is offline
Reply
Old 08-15-17 | 10:52 AM
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Concave = more braking surface in the same amount of physical space = faster stopping. Although with modern brakes this seems hardly necessary.
corrado33 is offline
Reply
Old 08-15-17 | 06:26 PM
canklecat's Avatar
10 Anniversary
Yeah, it's the mating surfaces. Those Jagwire pads I mentioned snuggle nicely with the PX-45 rims. Definitely better braking than the Kool Stops on the front wheel. I don't know that I actually need better braking on the rear since it mostly leads to skidding. I can already skid and dig into gravel and grass on the rear wheel with the Kool Stops and three finger pressure.
My Centurion Ironman has the original Araya CTL-370 rims, ultralight anodized with slightly convex braking surface. Trouble is, with the Suntour GPX group sidepull brakes there's no practical way to adjust the pads other than height and angle. No toe-in, etc., none of the adjustments we've come to expect, love and hate from good linear pull and canti brakes. I can see the pads only making partial contact with the rims. In two months I don't see any significant pad wear to indicate they're gradually mating with the rims.
OTOH, it doesn't seem to matter. The Centurion's brakes will lock up easily, usually with a one finger pull on either lever, no squealing. So while they could be improved in fit, it wouldn't necessarily result in better braking in actual practice.
Reply
Old 09-23-18 | 05:53 AM
Hi Bumbliwa!
Some time ago you wrote about the PX-45 :-D You still have them ?? :-)
Maybe you could help me with the following question?
I found them on a used kuwahara that I bouhgt recently with 33 or 35 tyres on and wondered to which extent I could buy wider tyres for that rim, like 37 or 42??
Best regards!
simon
simon hgy is offline
Reply
Old 09-23-18 | 06:37 AM
5 Anniversary
Bikes: 68 SS, 72 Fuji Finest, 72 PX-10, 77 Pana Pro 7000, 84 Pinnarello Treviso NR, 84 Trek 520, 88 Project KOM, 90 Trek 750, 91 Trek 930
I have PX-45 on a 96 Trek 720 with 35's on them.
dmark is online now
Reply
Old 09-28-18 | 11:25 AM
dddd's Avatar
Ride, Wrench, Swap, Race
15 Anniversary
I used to run skinny MA40 road rims with Panaracer Smoke 700x45c tires mounted. I raced three seasons on that setup and had no issues other than that it was hard to remove the inflated tire from between the brake pads.
One should avoid using any tube that isn't generously size-rated for the tire when using narrow rims, as there may be a tendency for the tube to over-stretch adjacent to the thicker rubber "pad" surrounding the valve stem as the air pressure may fail to settle this pad into the rim cavity as the tire is inflated.
So I always give the stem a tug after the first 5-10psi is put into the tire when using narrow rims with larger tubes/tires.
dddd is offline
Reply
67tony
Classic & Vintage
21
05-18-17 07:34 PM
Snowsurfer
Bicycle Mechanics
54
04-30-17 12:52 PM
Myosmith
Bicycle Mechanics
1
03-05-14 11:09 PM
octophasic
Bicycle Mechanics
6
12-21-11 11:43 PM
scoatw
Bicycle Mechanics
5
07-18-10 04:19 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
