Changing the middle chainring on Shimano Triples
Bikes: '08 Scott Addict R4, '09 Habanero Titanium Team Issue, '05 Scattante XRL, Mid 80's Titan Italian Steel, Trek 400 Elance, Trek 540 Touring Series, 80's Nishiki Single Speed
I am thinking about changing the middle chainring on my Shimano 105 & Ultegra Triple cranksets. I've notice that Shimano's 10speed cranks now come with 52/39/30 chainrings. My current setup is 52/42/30, and I want to change the middle chainring to a 39, will I need to change the front derailleur as well?
Thanks for you help.
40 something and counting
Bikes: Colnago,Tsunami, Kestrel, Univega
You'll be Ok with what you have. I picked up a used 105 9-speed group a few years ago. Ditched the granny ring and swapped the 42 for a 39.....It still shifts just fine.
good luck.
good luck.
Quoted: 2026 Post(s)
Liked 1,096 Times
I've played mix-and-match with Shimano road triples too. I routinely swap out the 30T granny for a 26T and have done just what you are asking about by substituting a 39 for the 42 middle ring for a friend. Worked fine with the original fd.
