Chipped CF frame
Chipped CF frame
Old 05-29-08, 07:27 AM
crusty
jbrians's Avatar
Bikes: Giant Kronos, Miele Appolo, Miele 12 spd, Diamondback Hybrid
Chipped CF frame
My 16 yr old nephew is a STRONG rider. 130 pounds of muscle and endurance, training for tri events (and winning many) in Ontario.
He is a bit hard on equipment though and has chipped the top tube on his LOOK CF bike down to but not into the fibre. about half the size of your little finger nail.
Can you apply epoxy or fibreglass resin on the wound or is smoothing the roughness off with FINE wet/dry paper good enough?
jbrians is offline
Old 05-29-08, 09:10 AM
Pleasurable Pain
greyghost_6's Avatar
Bikes: Voodoo Rada, KHS Alite 4000, Smith & Wesson Tactical, Diamondback Response
I wouldn't sand it and risk fraying the carbon. I would just use clear nail polish on it just to protect the one spot from scratching.
greyghost_6 is offline
Old 05-29-08, 09:17 AM
Perineal Pressurized
dobber's Avatar
I'd photograph it and contact the manufacturer. But it sounds like your describing a paint chip, in which case I'd just do a paint touch up.
This is Africa, 1943. War spits out its violence overhead and the sandy graveyard swallows it up. Her name is King Nine, B-25, medium bomber, Twelfth Air Force. On a hot, still morning she took off from Tunisia to bomb the southern tip of Italy. An errant piece of flak tore a hole in a wing tank and, like a wounded bird, this is where she landed, not to return on this day, or any other day.
dobber is offline
Old 05-29-08, 09:50 AM
jstraw97's Avatar
Bikes: Cannondale Synapse Carbon SL
+1 on the clear nail polish if it's just a chip in the clearcoat.
jstraw97 is offline
Old 05-29-08, 10:44 AM
Señor Member
theextremist04's Avatar
Bikes: CAAD10CAAD10CAAD10
I'd take it into your LBS and have them take a look at it just to be sure- it would be horrible if it wasn't just paint and you found that out the hard way.
theextremist04 is offline
Old 05-29-08, 12:06 PM
Joshua A.C. New's Avatar
Bikes: Iron Monkey: a junkyard steel 26" slick-tired city bike. Grey Fox: A Trek 7x00 frame, painted, with everything built, from spokes up. Jet Jaguar: A 92 Cannondale R900 frame, powder coated matte black with red and aluminum highlights.
Yeah. Just go ask someone. If it's just missing clearcoat, nail polish is the way to go, obviously. But you don't want to cut a promising biking career short due to a busted face.
Joshua A.C. New is offline
Old 05-29-08, 12:10 PM
capwater's Avatar
Bikes: Giant TCR Comps, Cdale R5000, Klein Q-Pro, Litespeed Siena, Piasano 105, Redline Conquest Pro, Voodoo Bizango, Fuji Aloha
Nail polish the chip, but keep a close eye on it. I crashed in a crit last year and thought I just had a chip in the clearcoat. Two weeks later of hard riding and I had 2 one inch cracks on the top tube! Carbon is tough, but when it goes it goes bad.
capwater is offline
Old 06-01-08, 12:14 PM
crusty
jbrians's Avatar
thanks for the replies!
jbrians is offline
Old 06-01-08, 12:43 PM
George's Avatar
Bikes: Specialized Roubaix
Quoted: 92 Post(s)
Liked 51 Times in 30 Posts
They have System 3 Epoxy at all boat stores. It comes in a small packet and it's a 2 part mix. Mix it up and leave it sit, but not long. After it gets a little thick apply what you need. Then put some Glad Wrap over it leave it dry. That should give you a pretty smooth finish, once you take it off. You can use a Dremel tool to smooth it some, but if you don't over due it, it should look OK. Now put the finger nail polish over that, good luck.
George
George is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
