Go Back  Bike Forums > Bike Forums > Clydesdales/Athenas (200+ lb / 91+ kg)
How to handle a "sudden incline"...
Clydesdales/Athenas (200+ lb / 91+ kg) Looking to lose that spare tire? Ideal weight 200+? Frustrated being a large cyclist in a sport geared for the ultra-light? Learn about the bikes and parts that can take the abuse of a heavier cyclist, how to keep your body going while losing the weight, and get support from others who've been successful.
Old 06-27-08, 09:15 PM
Hey guys and gals, I finally started riding again. My wife and I ride about 10-20 miles a day now(about 2 months into this highly addictive drug called cycling). I am a clyde at 5ft 9in and 226 and this thread inspired me to get on the bike...thank you all! Stupid question probably but...I ride in Florida which is very flat, and I ride on the Pinellas Trail. It is very flat and scenic where I ride, but at about mile 5 I hit an overpass over a busy street. You go from very flat to very steep. What is the best way to get over these things? I am always able to do it, but am very winded at the top. We usually just accelerate going into it and try not to have to shift too much, but it kills me! Is it best just to hit a granny gear and keep the same pace, or accelerate and try to race up these short (probably 50 yrds.) inclines? Anyone know what I mean? Thanks in advance!
Griffish
Griffish is offline
Old 06-27-08, 09:29 PM
c_m_shooter's Avatar
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times in 166 Posts
I ride single speeds, so I stand up and run at them. Others say that spinning in granny gear is easier on the knees though. If you want to get better at them, find one that good and tall and spend some time going up and down for awhile.
c_m_shooter is offline
Old 06-27-08, 09:42 PM
Frakabrash
Takabrash's Avatar
Bikes: '03 Marlin
I shift down and just start spinning. I don't try to go too fast up big, short inclines- I just try to not wear myself out!
Takabrash is offline
Old 06-27-08, 09:48 PM
st0ut's Avatar
Bikes: Wife Trek 7100, GT lola, specialzed Hotrock, Trek Grommet, dead Trek 5200(KIA rear derailer failed and brok frame), and Trek 720 (Died of neglect when the 5200 became a stable mate)
mmmm if you cann accelerate into it try to carry as much speed into hill. then down shift as cadence requires.
st0ut is offline
Old 06-27-08, 09:50 PM
theetruscan's Avatar
Do it over and over. If you do the same ride each time, start doubling and tripling that hill. After a little bit, the hill won't be so bad the first few times. Don't matter if you granny gear it or crank through it, doing more hills makes hills easier.
theetruscan is offline
Old 06-27-08, 10:27 PM
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6192 Post(s)
Liked 4,190 Times in 2,351 Posts
Griffish
For short hills (up to around 200 yards), I just stand up. There is some technique to it, however. Get your speed up before you hit the bottom of the hill. You should be spinning fairly fast but you don't what to be in too low a gear to start. As you stand, you'll need a slightly higher gear than if you were seated.
As you transition to the hill, make sure you hands are on the hoods, elbows slightly bent and a relaxed grip on the bars. Depending on the steepness of the hill, you'll need to move forward towards the bar. Don't worry about traction since road bikes usually have it in spades. I pull on the bars and throw the bike from side to side although you don't have to.
Here's a pretty good video showing how the pros do it. Of course you'll be doing it for a shorter distance and you'll have to keep a good line, i.e. not weave all over the road.
Stuart Black
cyccommute is offline
Old 06-27-08, 10:46 PM
Uber Goober
StephenH's Avatar
Quoted: 190 Post(s)
Liked 41 Times in 32 Posts
Just keep riding, it'll get easier. When you're coming up on it, start breathing hard before you need to, don't wait till you're out of oxygen and then start. Downshift to whatever gear it takes to keep from killing your legs. If you're on a single speed, just tear into it. Either way, there's no reason you can't stop at the top and admire the view while you catch your breath.
StephenH is offline
Old 06-27-08, 10:57 PM
+1
Richard_Rides is offline
Old 06-28-08, 05:16 AM
Just do what feels best to you. You can either speed up before you get to it and hope your momentum carries you up. In this case, you keep pedalling and try to shift down as you need to in order to maintain your same cadence as much as you can, OR, you can go into your granny gear just before you start the hill, shift the rear for a reasonable cadence and then gear down as you go up to try to keep that cadence. Try to do this all while seated, and save standing for nearer the end in case you need it. When you gear down, just momentarily relieve some pressure off the pedals to allow a smooth shift (but not enough to lose momentum, of course).
You're not in a race, so do what feels best for you. You don't want to burn your legs out on that one incline and then ride with tired legs the rest of the way. Non racers normally want to go the farthest they can while maintaining their ability to do so.
I would suggest that you will get the most from your body going up if you grip the handlebars as far forward as you can (hoods on a road bike, bar ends on flat bars). If you're riding a comfort bike, just forget it :-)
The more you do this little hill, the more you will be able to do it, no matter what you weigh.
Longfemur is offline
Old 06-28-08, 07:32 AM
Infamous Member
chipcom's Avatar
Bikes: Surly Big Dummy, Fuji World, 80ish Bianchi
Liked 4 Times in 3 Posts
yup, you got gears, use them. As you gain miles, strength and a good cadence, at some point you'll probably find that you can just power over.
"Let us hope our weapons are never needed --but do not forget what the common people knew when they demanded the Bill of Rights: An armed citizenry is the first defense, the best defense, and the final defense against tyranny. If guns are outlawed, only the government will have guns. Only the police, the secret police, the military, the hired servants of our rulers. Only the government -- and a few outlaws. I intend to be among the outlaws" - Edward Abbey
chipcom is offline
Old 06-28-08, 07:50 AM
Mr. Beanz's Avatar
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
I do the same but at the midsection of the hill, I will try to relax and find a confy cadence. Then towards the top section I shift up and do a hard effort., Like you, that's where most are winded and are easily dropped. If you practice, it will be you dropping the others at the top. If riding alone, practice this tech anyway for when you do ride with others.
Mr. Beanz is offline
Old 06-28-08, 08:07 AM
Infamous Member
chipcom's Avatar
I don't think the OP was looking to drop people, though perhaps he might like some alone time from his wife!
chipcom is offline
Old 06-28-08, 08:10 AM
This Space For Rent
Stujoe's Avatar
Bikes: 2007 Specialized HardRock Sport, 1982 Schwinn Super Le Tour
That is my game plan.
Stujoe is offline
Old 06-28-08, 08:16 AM
I was living in Boulder in the early 80s and a women's team from Holland came over to do the Coors classic. They had done all there training at home. Not too many mountains in Holland, so they did a lot of overpass repeats. They ended up performing pretty well in the Colorado mountains, so it appears overpasses can be a good way to build up your strength.
richking1953 is offline
Old 06-28-08, 08:19 AM
Prefers Cicero
cooker's Avatar
Bikes: 1984 Trek 520; 2007 Bike Friday NWT; misc others
Quoted: 3941 Post(s)
Liked 113 Times in 88 Posts
Depending on how smooth your shifters are, you may need to ease up on your effort and soft pedal as you downshift, so don't let your speed drop so low that you will actually stop and fall over while shifting, halfway up the slope. Shift down while you still have ample momentum.
cooker is offline
Old 06-28-08, 09:21 AM
Thrifty Bill
wrk101's Avatar
Quoted: 1236 Post(s)
Liked 963 Times in 628 Posts
Drop gears early (anticipate) and spin.
wrk101 is offline
Old 06-28-08, 12:40 PM
Ride because you want to
Take the advice here and try it different ways to see what works best. But really practice is the key and if you have only been riding a short time, you might not have the muscles yet. I have three hills that used to kick my ***** and now only one still gives me trouble, but at least i dont have to get off and walk anymore. I like to stay seated personally, because im afraid of the side to side movememnt that sometimes happens with standing throwing my cargo off the bike. But if you stand, you might noteven have to shift to a granny gear either.
guitarguy is offline
Old 06-28-08, 04:18 PM
Support JDRF
b_young's Avatar
Bikes: Specialized Sirrus, Specialized Roubaix Elite
Quoted: 52 Post(s)
Liked 3 Times in 2 Posts
Its a common theme but, try to keep your cadence up as much as possible. Don't worry about the speed. Shift gears to keep the cadence. The speed will come the more you ride it. I like to stand on a lot of hills. Shifting the bike back and forth keeps you from loosing energy from you shifting back and forth and keeps your movement in a straight line. It takes practice to get it right though. I stand as long as my legs will let me then sit and down shift a couple of gears to get the cadence back up.
b_young is offline
Old 06-28-08, 05:23 PM
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1786 Post(s)
Liked 1,259 Times in 868 Posts
Pushing hard (mashing) will sap your strength faster than spinning.
Anticipate your shifts. If you wait until you have to shift, it's too late. Think about shifting 20-30 feet before you have to. Adjust as necessary. You'll figure it out with a bit of practice.
You have energy built up in your crank and legs, Slow then down to a crawl and they want to stay at a crawl.
Bill Kapaun is offline
Old 06-28-08, 06:18 PM
Year-round cyclist
I don't think there is a right or wrong method. Some like to stand on the pedals and "beat the devil", but that's not my cup of tea and it's definitely not recommended if you have health problems.
There are two lower impact methods:
1. Lower slightly your gears and push hard through the hill.
You will most likely remain seated and you might drop, say, two gears at the bottom of the hill and two gears a little further on (or do one shift from large to centre chainring early on and one two-gear shift further on).
During this process, your cadence might drop from, say 80-90 rpm to 60 rpm and you'll push harder, but not overly hard.
2. Continue applying the same force on the pedals and continue to clip at the same pace
This is the easiest method and it works even for those 20-30 km long hills. Basically, you shift to lower and lower gears as needed. You won't ever feel your legs burning (but you will sweat, especially in Florida weather) and you will be able to climb really long hills, but it will be slow and you will use those gears that the shop told you they were ridiculously low.
Michel Gagnon is offline
Old 06-28-08, 07:22 PM
Hey all, great posts! Thanks much for the advice. I will definitely try some of these suggestions and see which works best for me...
Griffish is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
