Battery Mounting? Temperature?
Old 07-09-08 | 12:58 AM
Patriot's Avatar
Faith-Vigilance-Service
Bikes: Trinity, Paradisus, Centurion, Mongoose, Trek
We need a real LiFePO4 expert in this forum.
I recently got a brainstorm idea to use some 4x6" PVC rectangular piping with end caps to contain and seal a LiFePO4 battery.
Just wrap the battary pack in latex foam rubber, like I do with my RC model plane batteries, for vibration. I could easily slide it into the pipe, which would then have a hole drilled and a grommet used for the power cable. The ends would then be sealed with solid caps and PVC cement.
Totally waterproof. I could even drill a couple of very small drain holes on the bottom to allow moisture to drip out, if by some chance water got in there.
Would this be a safety problem?
Would overheating or lack of air circulation be a problem?
President, OCP
--"Will you have some tea... at the theatre with me?"--
Patriot is offline
Reply
Old 07-09-08 | 05:40 PM
Patriot's Avatar
^^^ If you are not using any kind of foam rubber insulation, how do you protect against vibration and physical damage to the battery pack when it's hard mounted to the rack?
President, OCP
Patriot is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
